Hey guys, I've got a Series II 33, 5 Spd, and when I change gears from 3rd->4th or 4th->5th the box crunches into gear. This does not occur when shifting down, either normal down shift or double clutch, and only occurs going up through the gears and when I am changing gears under full load/rev conditions. When driving the car around normally the only issue is that the change from 1st->2nd is notchy/clunky/grabby if you get my meaning. Now the first problem to me seems like a worn clutch that's slipping when the engine is at full revs or worn synchros. The second issue definitely seems like a synchro issue.
Thoughts and ideas would be appreciated and if you happen to know the associated cost with your suggestion/idea/opinion, please include that info.
Thanks!
https://www.sau.com.au/forums/topic/95454-gears-grinding-through-wot-changes/
Yep sounds like a synchro issue to me too...does it stop happening if you upshift more slowly?
If it happens stationery at idle its more likely to be a master or slave cylinder or clutch adjustment problem
Nah, if I shift slower (IE allow revs to drop more) it doesn't crunch, which to me implied synchros. What kind of $$ are we talking for this redline oil? In addition, how does this oil solve crunching issues, I'm assuming it's a different viscosity to standard box oil?
Cheers
how much is needed for a Series 2 R33 GTS-T?
Yeah that's what I'd like to know, hopefully at 120 for 3.7L that'd be enough.
As for speeds, I change at between 6k-6.5K when I'm giving it stick and the change from 2nd to 3rd occurs at around 90-100 depending on ambient temp, gradient of road etc etc etc. 3rd goes to about 140 or so I think but I'm watching the road closely by this point. My car is speed limited so you only just get to shift into 5th and it's @ 180. Of the few times I've done this it's on a few very quite back roads late at night by myself.
so the question still remains... is 3.7L enough?
Any1 know what prices the Motul and Castrol oils go for?
approx 3 litres for rb25, 3.7 is definantly enough.
my rb20 box took 2.5 litres from memory.
motul and castrol probably cheaper, though do a search for "redline" on the forum, and you'll see how many skyline owners swear by it.
"liquid gold" mate!!!
and how often does it need to be changed? is it every 5000k's like the engine?
The redline light wieght shock proof is excelent in the gear box - transformed my old wrx gearbox.
But no way I would leave it for 50000km. 10000 to 15000 max.
$120 for the large bottle is a good price.
  • 3 weeks later...
Duncan: by clutch adjustment, are you just talking the clutch pedal or is there some other adjustment in the hyrdaulic system?
Redline is the ony gearbox oil to use. Although it does look rather funky :D My car was crunching 3rd to 4th almost regardless of speed. It would do it putting along at 60km/h. Changed the oil to Redline and it hasn't crunched since, even at track days. . . . .
There is a threaded bar which the pedal uses to push the master cylinder, it can be lengthened or shortened if needed. But its not normally a problem, just an easy thing to try first
Well... turns out that I have some other weird problem. The clutch slave was pushing on the little paddle when fully released, which meant that it was disengaging the clutch slightly the whole time. SteveGTS4 (mate) helped pull it out, then we grinded a bit of the pin of the slave off, and it pretty much doesn't slip anymore. I have a new slave on standby if anything goes pear-shaped.
The new slave's pin was longer, being new and all, and fitted worse than the old one. We're thinking that maybe something else was changed when a button-clutch may have been installed in Japan sometime?
    • I thought Australia got rid of the "drag dodgy fuel up to 91 RON with ethanol", which is why all E10 advertise as "up to 94 RON" ? Anyway I put E10/91 in the missus' Mazda because she empties the tank weekly, when all my cars get 98RON. tl;dr - turbo - 98 RON, if you can't afford that, sell it and get a commuter car (or tune your car for 91, which no one does).
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
