  • Replies 109
just out of curiosity who else makes a similar kit to this? trust with TD-05??
Trust Td06-20g with 10cm rear housing would be about the same but then you need gate and manifold.
Also the td06 is plain bearing, oil cooled only, while the hks kit is ball bearing (think) water and oil cooled. also its newer which means new tech whichs should also mean less lag (hks says the GT pro s, is power and responds)
Cheers Michael :P
thanks for the map
look forward to the other also...
Does look similar... Timing is an issue im trying to deal with atm...
Will be going to mercury in the new year to get it sorted...
Edited by Col-GTSX
If you print this off and goto your ignition map - maybe just write down the differences?
Also had trouble uploading straight from excell so had to print off and scan onto a photo program.
I think I've got a boost leak so am going to make up a couple of bits of pipe - one with a blanked off end and the other with a valve fitting so we can do a pressure test - it really feels like I've got a boost leak.
AFAIK you can buy the dump separately. greenline are a better bet for a reply if you have a query.
i dont think this dump is available separately, it is specific to the 2835 turbo/kit. is it not?
that is correct :P
HKS make dump pipes for Stock R20/25 Turbo Flange, they also sell a GT dump pipe but that is only for EVO's and Sr no rb (and its still a stock setup dump pipe just comes with a hks front pipe)
If you think im wrong check the HKS website under extenstion
Got the car dynoed on a different dyno yesterday afternoon - no changes just a modern dyno dynamics dyno in shootout mode.
The 341.9 horsepower - in kw is 255rwkw - sounds much better than the 275 rwhp figure from the other dyno.
Interestingly the AFR's were reading differently between the units - the original tune was done with a motec and the tuner was tuning to afr's around 12.8 - 13.1 which I thought was lean - yesterday with the autronic lambda unit it was reading rich at 10.9 - 11.3 at full load.
We tried pulling a bit of fuel out but it lost power, then tried putting 1 degree of timing in - too much knock, then tried pulling out a degree of timing out and lost 20 hp.
The motec unit must read lean as at cruise with the o2 sensor switched on it was reading about 15.8, whereas the Autronic was reading 14.7 which is about right.
We didn't muck around with it - I just wanted to do a few power runs to get a dyno readout from a different dyno.
10 kw less thasn you sly 33 - I don't have a catch can though and have the stock airbox with k&n flat panel filter.
Cheers!
damn thats a nice power figure. I only managed 218rwkw with a GT30r and 470nm or torque I think. Torque was there but lat in the rev range (5k)
Here is my ignition map - (95 ron fuel) anyone wanna post theirs up to compare to mine?
timing.htm
would one of these hks 2835 pro's be to big for an rb20, would i see full boost by 4000-4500 rpm??
I don't think the unit is too big for a rb20. Physically it's not much bigger than the stock rb25 unit - probably similar to a gcg hi flow. You should see full boost by 4000. I can get 18 psi at 3000 - when I have access to a scanner in a few days I'll post up the data sheet from the dyno dynamics dyno - the power run was from 2500 rpm to 7000 and at 2500 it had about 16 psi. The print out shows intake temp, boost, speed and AFR's from memory.
I haven't been in any other rb25's with turbo upgrades but I can say the car goes seriously fast now - you can overtake in fifth no worries, 4th is quick and 3rd you have to be thinking quick and hang on!
Cheers
Yes it's done in silver. We made up the steel cover plates so they wouldn't coat the inside of the housing BUT they pulled the covers off and did the housing inside and out...?
Had the cat off the other day and noticed some tiny specs of the coating in it (smaller than a grain of sand) - the outside of the housing is fine though.
Just were a bit worried of what affect the bits of coating would have on the exhaust wheel but I guess we'll find out eh? Really hope it just gets blown out.
The coating cost about 70 dollars but if they are going to do the inside make sure they are going to do it in the more expensive black coating. This stuff comes apart at 750 degrees and you will most likely see 800.
We've been told it's basically impossible to get the stuff off once applied - even when sandblasting it just bounces off.
Cheers
excellent turbo kit, my results here:
http://www.skylinesaustralia.com/forums/in...4entry1487384
I need to spend more time on the dyno to get it up there, I am not 100% happy with the current tune. The adjustable actuator really confused the tuner, and couldnt be bothered to adjust it.
Cheers
cool, thats not too expensive then.
Do you think there will be any increased boost response due to more heat being retained? or is it just to insulate the engine bay from getting too hot?
Cheers.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
