I've got a 12" sub in the back on my R32.. but its' giving me the royal shits.. as the damn thing keeps sliding around and bunching up the carpet, and I end up finding it at all sides of the boot... and it ends up ripping its wires out from the amp. So i've actually taken it out as I had enough, and something was just going to get majorly damaged eventually.
Now the solution could be to stop driving like a mad person, but as we know, that's not going to happen.
so - how do most people secure a standard subbox to the boot of an r32?
I am not sure the best way to do it.. I was thinking of a strap or something, but secured to where?
The must be a fairly standard way to secure them to the boot, more specifically any pointers on an R32 gts-t ?
https://www.sau.com.au/forums/topic/96025-securing-a-sub-ideas/
haha...i have an r33 with the same problem.....wat u can do is be smart and buy some corner brackets (those 90 degree thingos from bunnings) and jus screw it in2 ur floor....ordo wat i do...backseat...and belt it up.hahahaha
hey,
i went to a hardware store and bought a strap with one of those little clips that you can push on and pull the strap tight. on my 34 i was able to thread it down behind the back edge of the carpet and the through some of the metal structure of the boot floor and back out over the top of the sub box. also makes it easy to take the box out if you're going to the track or need to get at your spare.
my car doesn't have the bit of wood stuff for the boot floor but the other option is to get one made one up and screw the box onto that. the sub still might go flying as you pull -1G getting air though. :)
I found a bolt welded to the underside of the parcel tray support. Bolted a bracket made from flat aluminium 40mm x 2.5mm that goes across to the box and down to a mounting point on the side then another bracket was made with the same stuff. It was L shaped. The bottom part of the L goes parallel to the floor and you take out one of the rubber bungs and put a bolt through to another flat piece of aluminium.
You then cut a slit in the carpet which can't be seen when you remove the bracket and the side of the L shape goes up through that to the same mounting point on the side of the box.
This is a really solid mounting which is totally removable. I could go to a track day with it in I'm that confidant of it's strength. The only left over thing if you remove it is a slit in the carpet which you can't even see.
velcro wouldn't be the best, as the problem is the whole carpet moves.. I build an aftermarket mdf floor, so its a bit slipperier than the old piece of cardboard stuff..
Abobob I think has what I was leaning towards... will try some of those ideas soon. Strut brace could make it a lot easier, but don't have one of them.
It's just stupid when it flies around like that.. doesn't even require that much, as the tail always gets the most amount of momentum and anything inside just slides back and forward.
No offense intended to you or anyone else but I think putting 15" subbies in cars is one of the stupidest ideas out there.
Eg; a average kick drum sound has most of it's energy at around 63Hz. A 63Hz sound wave takes 16 feet to travel one cycle. So unless you are 16 feet away from the speaker or more, a very large proportion of the awesome output of a 15" subbie is completely wasted on you.
All you can hear in the car is reflected waves.
This explains why people on the street can hear perfectly the sub bass created (and the number plate rattling) but the idiot in the car doesn't even think it's turned up that loud.
Please don't screw it into your floor.. I think that's the fuel tank :)
I've got a rear strut brace, what I've done is bought some cargo looking strap things for $20 from super cheap auto. They are the ones that are flat tape with a lever on the end so you feed the tape through and make it tight with the lever.
I used them both to secure the sub to the brace and it ain't goin nowhere but is still removable for the track etc.
Otherwise mounting brackets into your seats or something - just make sure you don't use a screw too long to stab your passengers, or too short so it falls out.
Good luck.
I put some velcrow on the base of the sub. And the that to the carpet. Then lifted up the carpet, and put some of that grippy sheet stuff, simliar to the stuff you use to open hard to open jar lids. As my sub covers my jack this makes it heaps easy to move. As I just lift up the sub, yet it doesnt move unless I pick it up.
Try it anyway.
velcro could even be enough, true..
Please don't screw it into your floor.. I think that's the fuel tank tongue.gif
yeah, not a good idea.. anyhow, I have worked out what I'm going to do.. Buy some rears, use my old 2 channel I have had sitting there for 2 years doing nothing.
I've built a basic replacement wheel well cover using MDF. Will just make a new one a bit larger (mmm, jigsaw) more in the size of the carpet shape, and screw both my amps to that...
Then use a couple of _| brackets to screw into that, and hold the sub in place at two diagonals. To remove, I simply lift up the sub and over the brackets (and hopefully I won't be getting the car airborn too often :)). This method the carpet will be held in place by the amp screwed to the MDF below. I can also run the cabling a bit later under the carpet, and do a few small holes for it the cables to pop up near the amps, subs, etc so its not spagetti city.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
