must be something with 19 yr old girls and lowered cars then Gradenko because thats how old i am. My car handled fine being the height it is before the stops packed it in - you still feel the road a little more than a standard but it wasnt enough to make the cd player skip back then.
If it aint broke dont fix it :starwars:
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-156761
  • Replies 60
If it aint broke dont fix it :P
But if the stops are broke then it is.
A properly setup suspension should only hit the bump stops occasionally , not all the time.
Even the rally cars only get the bump stops refreshed about once a season
If it ain't broke then don't fix it means that you spend your whole time trying to maintain the car.
Trick is to IMPROVE it , make it FASTER , make LIGHTER , make HANDLE , make it leap tall buildings in a single bound.....
:lol:
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-157144
Im getting it fixed - it just takes a bit of money so once that comes in it'll be back to how it was before - which handled great it grips the road has hardly any roll just a back end that likes to slide out hahaha
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-157500
$500 here, $500 there, where does it stop? I am trying to be sensible about my car, but I need everything done now. I never thought too much about suspension, but my car is incredibly uncomfortable on a bumpy road. I have HKS adjustable suspension, but I have no idea about the springs or anything like that. When I asked my mechanic to lift the suspension he said it is at the optimum hieght for performance, and something to do with campher.
Is there a cheap way of making it run a little smoother?
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160664
Youve also gotta realise that most Japanese springs and shocks, coilovers included and F'IN stiff. Like REALLY stiff. Pedders and Kings products provide a much nicer ride and in some cases better handling than the jap stuff simply because the car isnt tracking over bumps in the road all the time.
Ive got Tanabe shocks with Apexi springs and its about as stiff as id like to go, any more and it becomes jarring to drive. My mate in rocko has an EVO4 with Bridgestone Potenza coilovers... yes suspension made by a tyre company.... i have NEVER ridden in a more uncomfortable car in my life... felt like the shocks were just steel bars.
Red17
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160684
haha i always thought fremantle catered for the lowered car lucky you werent up in the hills with us hillbillies - you only get one chance when you take on a curb up here - took on one about a year n half ago and lost!! My poor Z31 had to be towed away because i blew out a tyre and couldnt find the lock nut haha!
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160730
If it's adjustable for bump you could try softening them off but it's probably the springs are 90% of the problem.
Ohh and it's Camber which is the inward ( negative ) or outward ( positive ) inclination of the front wheel from perpendicular.
LOL *campher*
That will stop the moths from eating the seats.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160749
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
