i just removed wheel .. covered hub in news paper and wheel arches and side of car and sprayed in my garage with no wind ..
make sure u tape correctly and make sure you get all the paint off if you didnt mask the disc could smell funny or cause irregular braking which you obviously dont want
I did that too, took about 2hrs total, will post up some pics. I did my hubs black and calipers red (black car with nismo wheels). Plan to just file back the NISSAN lightly - prefer natural metal colour to the white.
  • Replies 155
Posted Images
no i haventseen the logo painted white.it whold look good against blue callipers.
before
after
The paint colour is still the best i have seen of any heat proof spray in a can.
This is the before a track day in summer and after.the heat has slightly faded the colour but it is still good none the less.
I think wat he Ment was, Taking them fully off Including Disconnecting the Brake lines and draining the system
Which is what I had originally Planned to do Untill i saw this thread! great Thread btw!.
My idea is to re-Paint the white, (why not give it all a freshen up I thought.), using a Fine Paint brush.
Edited by silverbulletR33
  • 4 months later...
Hey I know it's been like ages since I said I would do this, but I finally painted my Nissan logos white. I did an OK job, just used a fine paint brush and some cheapo white spray paint that I got from Super Cheap. I've had them painted for about 4 months now and they haven't chipped or faded yet. Sorry for the crappy pic (again).
  • 4 weeks later...
They look really good!! i have read this thread and have decided on painting mine gold with the nissan logo either, chome, black or green (like my car) i have begun by preping the brakes, by sanding them back. I have my calipers off the car, as i have a skyline r33 gts with rb25det conversion so i am going to put the brakes on as soon as i can, i thought while they're off why not freshen them up?? great thread!
hame
  • 1 month later...
I just took my Brake Calipers and rotors of again as i found the vht paint scratches to easy and i f**ked my nissan logo up(trying to paint it white) Now im going to paint them gold just not sure if i should have another go at painting the nissan logo white. Also can i use some type of clear coat to give them extra strength to stop the rotors from peeling when i change the wheels.
Cheers
Dave
hey guys i tried doing mine today i have preped the calipers and i used one can of duplicolour metalcast mc202 yellow with gold finish and it is not looking great at all! i have used the whole can on the two calipers and they look funny i'll post up pics asap
hamish
heres the pics, it like the paint wasn't thick enough or something, think i should get another car n go over the top? i did not use a primer but i was told by the guy at autobarn not to as the paint did not need a primer...
hamish. :D
it appears that the colour u choose doesnt cover easy, get a can of the ground coat for it cover it with that, then apply the other paint and it should come up nice
I just wrote a post in anodisation of calipers but Ill run it past your guys..
Screw white because it looks shocking.. If you do decide to do it .. get a nail painting brush and apply it.
If not when you paint your calipers either file it back when dry.. if you already have them painted then this is best.
Or when semi wet (i.e 2 mins after painting) use your thumb wrapped in masking tape to stick onto the nissan sign and pull off at speed.. Watch it come off.. If its not comming off wait for it to dry some more..
Just spray over it with clear as its easier to clean once you do that, hope that helps everyone here
H@ME.. Try spraying it again when the calipers are cold and not hot.. Either that or dont spray them on a humid or wet day .. Try shaking the can for longer and soaking it in boiling water (dry the can totally as ive dropped water onto the paint once and I had to strip it back - damn perfection crap)
Can in the water will make the paint mixture thinner and easier to apply for one.. For your first coat go light, increase in second and heavy in 3rd.. This will allow a shinny base .. then smash it with clear.. All heat proof..
H@ME if you want gold look up the anodisation section for brake caliper .. It will look alot like brembos on 34s.. Paint will look shithouse
Edited by DECIM8
thanks for the advice guys, i have read a few thread on here regarding painting brake calipers anodizing etc, the paint looks a bit better today it has now a nice shine finish to it. So should i go over the paint on it now in the dulicolour Mc100 ground coat then hit it again with MC 200, or should i just try a few more coats of th mc200? regards hame. here is a recent picture.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
