  • 1 year later...
  • Replies 155
Posted Images
hey just a quick tip that would save you a heap of time, instead of masking up the rotor and stuff, just apply a thin layer of grease, heaps quicker, let everthing dry well, rip a can of degreser out and a hose and your done.
i didnt bother with the top coat, the finish of the anodized paint was enough for me
as for the cracking/peeling on the track - not sure on that, they say its rated up at 500 F (approx 260 C) intermittently, so how hot do your brakes get???
A friend of mine welded his wheel nuts to the wheel studs :) They get hot.
If your pushing it for a few laps hard, id say youd breach 260 pretty quickly.
The rotors i have on my R33 have a 600 degree indicator on them.. what does that tell you lol.
If your not going to track the car then normal enamel or acrylic paint will do the job. normal automotive paint is heat resistance up to a certain temperature. i know for a fact because i painted my previous calipers with two dollar store paint and lasted. just make you use lots of clear for protection. let it cure properly.
  • 2 months later...
I'm gonna give this a go. Abit of a bump yes but something like this will always be looked for. Great writeup. Ill be doing this on my R33 GTST fronts first then rears. Going to use Duplicolor metalcast orange/yellow(which ever I can find). Will post up how it goes. I cbf taking the calipers off the car. I only just done the brake lines and used some good fluid in there so ill just unbolt them and dangle them off the car.
  • 3 months later...
I'm sure it been mentioned but does the clear come in a heat resistant too?
The tins I've looked at are just a colour heat resistant to 'x' amount of degrees but I haven't come across any clear yet. I'll keep looking. I'll do mine in a few weeks, just the standard black with white Nissan.
3M heat proof spray paint is rated to 650c and comes in clear also. can get from supercheap.
I done mine in the aluminium colour then clear. Done about 6 months ago and looks as good as when first done. Ill take pics if you want.
Yo GoHard! Cheers for that!! I have a grey 32 GTR, and after seeing the pics of the dude sparaying his brembos silver I was thinking about doing the same. But I also really like the black with white Nissan... To many options!!
I hear ya.
I ended up going with the silver because my car is silver. don't regret it.
To save pissing around with masking/painting the brembo, you can get off ebay for sfa some high temp brembo vinyls. not sure if they hold up but its worth 5-10 bucks?
  • 1 month later...
Ive always used normal cheap spray paint for some reason heat hasn't affected em. Tho I don't do track or anything. My last car I painted em Baby blue/green and printed some Project Mu decals, glued them on lol looked sick! Peps at the car show thought they were real haha this was a Evo with bremebo brakes tho btw. Gotta love painted brakes so simple yet so affective.
  • 9 months later...
Looks sweet, well done.
Have to get around to doing this some day and maybe do the ugly rust bits of the discs too.
Now you just need to change you sig pic so the calipers are on the correct side. ;)
Edited by Not a Pulsar
Thanks, definately worth the effort (not much effort actually, just a lot of waiting haha)
Is it bad to paint the rusty bits on the disc, since it's not the actual disc itself? I do want to get rid of the rust somehow, but not sure how to go about it.
Would like to make it black, match the rest of the black and gold theme i got lol.
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
