i just removed wheel .. covered hub in news paper and wheel arches and side of car and sprayed in my garage with no wind ..
make sure u tape correctly and make sure you get all the paint off if you didnt mask the disc could smell funny or cause irregular braking which you obviously dont want
I did that too, took about 2hrs total, will post up some pics. I did my hubs black and calipers red (black car with nismo wheels). Plan to just file back the NISSAN lightly - prefer natural metal colour to the white.
  • Replies 155
Posted Images
no i haventseen the logo painted white.it whold look good against blue callipers.
before
after
The paint colour is still the best i have seen of any heat proof spray in a can.
This is the before a track day in summer and after.the heat has slightly faded the colour but it is still good none the less.
I think wat he Ment was, Taking them fully off Including Disconnecting the Brake lines and draining the system
Which is what I had originally Planned to do Untill i saw this thread! great Thread btw!.
My idea is to re-Paint the white, (why not give it all a freshen up I thought.), using a Fine Paint brush.
Edited by silverbulletR33
  • 4 months later...
Hey I know it's been like ages since I said I would do this, but I finally painted my Nissan logos white. I did an OK job, just used a fine paint brush and some cheapo white spray paint that I got from Super Cheap. I've had them painted for about 4 months now and they haven't chipped or faded yet. Sorry for the crappy pic (again).
  • 4 weeks later...
They look really good!! i have read this thread and have decided on painting mine gold with the nissan logo either, chome, black or green (like my car) i have begun by preping the brakes, by sanding them back. I have my calipers off the car, as i have a skyline r33 gts with rb25det conversion so i am going to put the brakes on as soon as i can, i thought while they're off why not freshen them up?? great thread!
hame
  • 1 month later...
I just took my Brake Calipers and rotors of again as i found the vht paint scratches to easy and i f**ked my nissan logo up(trying to paint it white) Now im going to paint them gold just not sure if i should have another go at painting the nissan logo white. Also can i use some type of clear coat to give them extra strength to stop the rotors from peeling when i change the wheels.
Cheers
Dave
hey guys i tried doing mine today i have preped the calipers and i used one can of duplicolour metalcast mc202 yellow with gold finish and it is not looking great at all! i have used the whole can on the two calipers and they look funny i'll post up pics asap
hamish
heres the pics, it like the paint wasn't thick enough or something, think i should get another car n go over the top? i did not use a primer but i was told by the guy at autobarn not to as the paint did not need a primer...
hamish. :D
it appears that the colour u choose doesnt cover easy, get a can of the ground coat for it cover it with that, then apply the other paint and it should come up nice
I just wrote a post in anodisation of calipers but Ill run it past your guys..
Screw white because it looks shocking.. If you do decide to do it .. get a nail painting brush and apply it.
If not when you paint your calipers either file it back when dry.. if you already have them painted then this is best.
Or when semi wet (i.e 2 mins after painting) use your thumb wrapped in masking tape to stick onto the nissan sign and pull off at speed.. Watch it come off.. If its not comming off wait for it to dry some more..
Just spray over it with clear as its easier to clean once you do that, hope that helps everyone here
H@ME.. Try spraying it again when the calipers are cold and not hot.. Either that or dont spray them on a humid or wet day .. Try shaking the can for longer and soaking it in boiling water (dry the can totally as ive dropped water onto the paint once and I had to strip it back - damn perfection crap)
Can in the water will make the paint mixture thinner and easier to apply for one.. For your first coat go light, increase in second and heavy in 3rd.. This will allow a shinny base .. then smash it with clear.. All heat proof..
H@ME if you want gold look up the anodisation section for brake caliper .. It will look alot like brembos on 34s.. Paint will look shithouse
Edited by DECIM8
thanks for the advice guys, i have read a few thread on here regarding painting brake calipers anodizing etc, the paint looks a bit better today it has now a nice shine finish to it. So should i go over the paint on it now in the dulicolour Mc100 ground coat then hit it again with MC 200, or should i just try a few more coats of th mc200? regards hame. here is a recent picture.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
