  • Replies 315
wow....alot of respect for your build mate....its not only painful to fork out the $$ but more so in the time it takes to get it together and on the road!!
but its worth it, at the end of the day u'll have an awesome setup!!
cant wait to see the figures it pumps out...its going to be a beast
Looking good Brad. Well done. Make sure you post up the graphs when she hits the rollers.
I thought my Stagea was nice, looks like a piss ant POS next to this.
ken
Edited by RBNT
Very nice conversion, may I ask what sort of money to build just the motor? (Pm if you like).. And why you went the JUN 2.7lt? And say not the Tomei 2.8lt? Or even HKS for that matter.
I'm currently looking at the Tomei 2.8lt, but are still in heavy research mode until my gtst goes to free up money, so I would love to hear pro’s and con’s and everyone’s opinion.
Yeah im interested in some info too, alternatively, did you look into buying say a complete engine from Tomei/mines etc brad?
yes im leaving the standard harmonic (at the moment) which limits the rpm to under 9k but for 500rwhp i wont need to rev it that hard, and the engine parts i choose because they were offered to me second hand, and i want the revving nature of the 26 to remain, as ive had a rb30 and it was a truck engine in comparision (slow reving), but i've explained it all on page 1 and 2 of the thread, and cost of the entire engine and external parts, plus fuel system, ecu, and everything to make the power is over 40K if i bought the bits new, and ive spent over 30k in reciepts, and thats JUST PARTS, NO labour. (cause i saved 10k on the second hand bits, though they were unused and still in boxes).
now u can see y im abit anxious about the build :rant:
crank is limited to 11k for safety, and 13k rpm for extreme applications i've been told.
im abit annoyed i've spent soo much and only want 500rwhp at the moment as i've gone total overkill, and coulda used stock parts in the build, but i always want room for more power, and next target is the t04z's limit which is 700rwhp, and then i might get another larger turbo to push it even harder and get above 700rwhp. The engine combo is rated to 800-850rwhp or so with a trust t78 by the JUN head guy. or over 1000rwhp with a t88.
I cant imagine how hard it would be to tune an engine like that on the dyno. one little bit of knock that you cant even hear and BANG its blown up before you know it...
What im saying is that it takes serious tuning skill and knowledge to get a beast like that running to its potential...
Cheers,
Matt
PS - cant wait to see it roaring down the strip :)
Edited by MattSR
So what are you going to make the limiter assuming you change the balancer?
9500rpm?
And yeh you better have alot of faith in your tuner!
not sure, as the gearbox wont shift above 9k rpm and i need oversize pulleys to prevent blowing the air con compressor up and to slow down the power steering and water pump (n1 which flows less already so might get hot in traffic with an oversize pulley and cruising speeds)
i think the need for over 9k rpm wont be very often as it is going to be a street car and not a drag/track car, so i need it reliable in traffic as much as possible, i have another daily driver, so wont be drivin it more than 1-2 times a week for cruises on weekends, or maybe the occasional thrash after work :P
the tuner i am using, does race/rally cars, and high power street cars, currently his best hp is just under 700hp at the wheels from an evo 6 i think (2L turbo)
just sorting all the fuel lines at the moment, and god damn they are pricey :P
spent $400 on turbo braided lines for water and oil
another $350+ on fuel lines and fittings
and i still havent got everything yet. B)
cheers
Brad
Just a quick question are you feeding your fuel rail from both end with the return from the centre, as i can only see feed on the front?
pete
yes it has twin feeds one from each end and then the return in the centre :)
its a Sard fuel rail
I assume controlling it will be something like the silver Stagea a few minutes into this video clip http://video.google.com/videoplay?docid=-8...3&q=Skyline+GTR :(
Thats stagea is nuts.... Cyrus would like this....
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
