Guys,
Used the search function, but could only find info on RB25.
I've just installed a set of Apexi RX6B turbos (come onto boost at 5800) onto my gtr and need to know what the safe limit of a standard RB26 is?? I used to run a Tomei chipped computer and the limiter was set at 8426, but have now just swapped over to Autronic and need to know how high i can set the limiter, without hurting the engine. The motor was rebuilt to standard spec's about 15000k's ago.
Thanks for the help..
https://www.sau.com.au/forums/topic/98638-rb26-rev-limit/
agreed, and it's not really worth it. when i'm racing the GTR i actually knock the limit down to about 7600 or 7800 as the limiter can be a little lazy, and i'm mostly shifting up before then anyway, no need to ring it's neck all the time.
https://www.sau.com.au/forums/topic/98638-rb26-rev-limit/#findComment-1795497
The top end will take the high rpm all day.
But the bottom end is still standard production motor quality and piston speed should be kept under 4000ft/min.
Unless you have a fully balanced and light weight bottom end components don't rev it above standard rev limiter.
Standard cams won't make power up at those levels anyway typically, so why rev it.
https://www.sau.com.au/forums/topic/98638-rb26-rev-limit/#findComment-1796813
Turbos were bought 2nd hand off these forums, unsure which version they are. 1.1 - 1.3 bar at approx 6500/6600rpm Yes, i do now realise that these turbo's are mismatched to a standard motor, but i guess thats all part of the learning process hey...Although im no mechanic, when i bought the turbo's i though that they would have come on earlier due to only having smallish exhaust housings.
https://www.sau.com.au/forums/topic/98638-rb26-rev-limit/#findComment-1804894
8200 max
they can spin harder but the rev limiter will bust the oil pump.
i mist a gear in my 170000km 32gtr with a blitz access ecu it hit 8878 on the multi checker!!!!! it has hapend 3 times now :)
i put it to the fact that the revlimit doest bounce the crank back and forth
on my other motor
(revalant mods to this topic,n1 oil pump 33 engine)
it saw 8200 regulary whist wheelspinning :lol:
it cut a long story short i rebuilt it after a turbo falure and the pump had copped a pounding!!, quite alot of ware around the pump drive surface
https://www.sau.com.au/forums/topic/98638-rb26-rev-limit/#findComment-1804941
virtually all rx6 twin kits for a gtr would be classified as a drag spec turbo...
unless you feel the urge to spend up huge amounts of dollars engineering the car around the turbos i would say it would be best to bite the bullet and start over again
even on only 1.1 to 1.3 bar i dont like the chances of ur engine lasting very long no matter what you rev it 2
https://www.sau.com.au/forums/topic/98638-rb26-rev-limit/#findComment-1805550
i was talking to a guy that had done all his internals and stuff, he didnt see boost til 6000rpm through to 9000rpm which is where his rev limiter was, but that was rebuilt. if ya wanna increase the rev limiter u should/need to upgrade the fuel system, oil and water pumps and yeah stronger inturnals
https://www.sau.com.au/forums/topic/98638-rb26-rev-limit/#findComment-1829820
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
