  • Replies 100
Posted Images
lol new Zeds = the crap old school Zeds = Nice :)
the old VG30 single cam single turbo motors in the old Zeds have more power then the quad cam twin turbo motors in the 90 models B)
CLASSIC NOT PLASTIC!!!!!!
:lol: :lol: :lol:
OK guys i must admit, i got extremely pissed one night and when i got back, noticed my housemate Zor was logged in on the forum.
Couldnt resist having a laff...
Completely forgot doing it until my mate just came across this thread!
Soz man... :)
I'll never do it again... (sober)
First of all....why would you buy a car that weighs like 2 tonne, they are renowned for blowing heater hoses under the inlet manifold, you can't change the turbos on them without basically removing the engine - which takes around 18hours on a hoist, they have no balls coz the car weighs so much, they look like a boat, they drive like a boat, the bottom end is nothing to run home to mum about and they are way too overpriced for the overall package. WTF?? I know a guy who owns two and he has had the worst headache since buying them coz they always need repair and they cost a fortune. The labour charge is like 2-3 times more because everything takes that much longer to repair on them.
I don't care if they are Nissan's, they are no son of mine. I have disowned them.
END RANT.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
