Hey guys and girls, just after some feed back/ideas on things I should look into with getting my rb25 on boost quicker and to make it a lot more power happy down low, current mods as follow below;
Rb25det rebuilt with forgies, ported head, HKS 275 camshafts, top mounted trust Td06-25g turbo, trust 50mm waste-gate, trust front mount intercooler, trust Oil cooler, GReddy Type-R BOV plumbed backed, 850cc injectors, 3inch dump pipe, 3inch dump pipe back exhaust and an evil HKS F-con V ecu.
I understand it will never be as exciting as it would if it were a smaller turbo, but I'm sure there is something to make it a little less boring until 3800rpm? I assume the tune would be a big factor? Would getting the f-con re tuned or even ditch it altogether help?
Thanks.
https://www.sau.com.au/forums/topic/99396-my-car-is-a-laggy-pos-suggestions/
A bit more info of what power it is making now, what boost and even better a dyno sheet would help.  But if you are making meaningful power, and it gets going at 3,800rpm...i dont think you are going to improve much on it
490rwhp on around 1.5bar with advanced timing and jungle juice.
was gonna say that wouldnt be street fuel :P
getting a -25g coming on @ 3800rpm IMO is pretty damn reasonable.
Its a trust turbo... thats thier behaviour.
Nothing nothing nothing... KAPOW
Where is it making 1.5bar?
Can’t really remember 100% as my dyno sheet is in another country (long story don’t ask). Pretty sure it was very high 4000rpm, maybe early 5000rpm, either way it starts to sing at 3800rpm.
I have my suspicions my turbo is a freak.. Some form of high flow jobby, not really sure.
I don't see why you are complaining.
My car is boring and has no life off boost. I was hoping maybe a different cam shaft selection or maybe trial and error on the dyno with some tuning would make it more lively in the low rpm range. I know I will never get that “kicking you back in the seat” feel a nicely set up GTR with aftermarket low mounts have off the mark, but a td06-25g really isn't that big of a single to make my car feel like a diesel Pajero until 3800rpm B)
sounds about right in the high 4000's.
thats just the turbo. you might get 200-300rpm better with r&d, but not much more
Typical non-ball bearing turbo eh. I had quote from GCG to convert it to ball bearing, worth the time and money in every ones opinion? Or is my money better spent elsewhere?
I was not aware you could make a mitsubishi into a garrett.
try retarding the exaust cam abit(like 2-3 crank degrees)
those cams wont help,what exhaust housing is on it.
is it a tdo6H or a td06 (25g ie t67)
ive got a 14cm tdo6 housing that may suit. but you need a 10-12cm one it seems
they are a mad turbo but hit with a rush. :lol:
running shorter duration on the cams generally gives better low down power, maybe stepping down from 272's to 264's
playing around with cam gears you should be able to shift power around on the rev range
running higher compression with thinner gasket if you have a thick one, higher compression will again give better low down response
maybe lightened flywheel as well, wont change the power your making, but will make the car more drivable when its off boost
theres some suggestions, the first 3 will most likely lower top end though
Thanks for your reply’s lad's.
R31Nismoid, I think if I went to a completely new turbo I'd just buy a HKS 3037 or something, I doubt second hand turbos are worth much, almost wouldn't be worth while selling mine.
T04GTR, mine is the 25g exhaust housing.
mokompri, I'm running an OS Giken flywheel and twin plate clutch so I guess the flywheel should be lighter enough? I'm going to look into cam price's I think, losing top end HP doesn't really faze me much these days, I guess I'm just after an extremely toey street car, with minimal lag with out having to change anything really major.
If only we could have it all lol ;)
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
