I would like to thank Sky30 for buying my car. It has served me well over the last three years with many good times. I hope he can have as much anjoyment and pleasure as i had with the car. I am glad to sell it to a fellow enthusiast.
hope everyone has a very merry christmas and a happy new year.
Cachya round people's it has been great. :(
R32gts4
AKA - shaun
https://www.sau.com.au/forums/topic/99612-sold-my-car/
hahaha, So you finally went the GTS4. :D
Awesome.. I can't wait until its running, should be much MUCH more fun.
Second gear roll on's out of corners are now going to be rather waaaaaaaaaaaaaaaaa.
What was the GTS4 worth?
Edited by Cubes
https://www.sau.com.au/forums/topic/99612-sold-my-car/#findComment-1815983
who u talking too
https://www.sau.com.au/forums/topic/99612-sold-my-car/#findComment-1815994
Yes I have an Rb30 in my R32 GTST as does Sky30.
Sky30's plan as he stated is to put the rb30 in the GTS4. :D
Shaun- Got the car home no worries, cant wait to get the 3.0L in there.
The only extra cost dropping the RB30 in the GTS4 is the $450 sump adaptor.
Edited by Cubes
https://www.sau.com.au/forums/topic/99612-sold-my-car/#findComment-1816123
so how much is the whole job and having a RB30 is that called the RB28 stroker
https://www.sau.com.au/forums/topic/99612-sold-my-car/#findComment-1816188
The RB30 is a 3ltr, the 3ltr from the R31 Skyline or VL Commodore. Not a 2.8ltr.
The 2.8ltr stroker kit is bought from japan from Jun.
Sky30 used a second hand running 270,000km's RB30, dropped it in his R32 GTST bolted on a R32 RB25DE head and off he went - Very side ways.... :D
$$ - What ever a second hand RB30e and r32 rb25de head costs, + a few gaskets and the modification of engine mounts. ~$70 if you pay some one to do it.
If you are a little mechanically minded the job can be done for rather cheap.
Edited by Cubes
https://www.sau.com.au/forums/topic/99612-sold-my-car/#findComment-1816195
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
