hi guy is there any way that we can get some rwd stagea things going like tutorials and diy
What are you trying to do that you can't figure out?
Or do you just want people to spend heaps of time making tutorials on stuff that isn't required just on the off chance it might help you in the future?
  • 3 weeks later...
anybody know what the little steering wheel switch is for on a c34 s2 tiptronic auto?
Yeah it enables the gears to be changed via the steering wheel controls when the shifter is pushed to the left.
Edited by stock stagea
  • 9 months later...
  • 1 year later...
  • 7 months later...
How to repair seat switches in the M35 Stagea.
You MUST find someone with a proper, professional quality desoldering iron. The switches are pure copper and will suck up heat easily. Seat_1.JPG
Steps:
·        1)  Remove seat.
·        2)  Remove switch PCB from seat.
·         3) Remove switches from PCB.
·        4)  CAREFULLY lever switches apart (I used a Stanley™ knife blade), taking care not allow springs to end up 10 Metres away, by removing the switch cover.
·         5 Burnish and clean the switch contacts.
·         6) Condition switch contacts with De-Oxit™ or equivalent.
·         7) Allow to sit for a few minutes.
·         8) Clean off excess De-Oxit™.
·         9) Place a minute segment of Blu-Tack™ on the end of the two springs and re-insert.
·         Here is where you need 4 hands:
·         10) Place a loop of strong cotton (I don’t like using mon-filaments, but use whatever you like – it must be fine enough to allow the switch cover to be re-installed whilst the cotton is in place) around one end of the switch body.
·         11) Replace the two switch levers and ball bearings.
·         12) Install both switch actuators.
·         13) Ask you second pair of hands to place a second loop of cotton around the other end of the switch.
·         14) Both switch actuators should be reasonably secure at this point.
·         15) Replace the switch cover.
·         16) Cut the cotton.
·         1 - 16) Repeat as necessary for other switches.
·         17) Re-install on seat.
·         18) Re-install seat.
Happy days.
  • Like 4
  • 3 years later...
Just an outside chance it could be for 2wd operation if you have a 4wd but don't try it til you have read this:
hmm the below is for a C34 - don't know if it applies to your car....
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
I have hooked mine to a switch in the centre console.
On 05/07/2020 at 12:34 PM, LieutenantJiggles said:
anyone know what this "off" button is for? To the left of the hood release, under wheel. (2004 2.5L Turbo four)
That turns off the optional factory remote start system. Dealer fitted accessory, mine was mounted at the top of the driver's kick panel. Comes with about a mile of addition wiring under the dash too for maximum clutter
So it is important if I have an aftermarket starter, was thinking of putting my kill switch there. Also, do you know if a Stagea's aftermarket steering wheel is the same mounts/adapters as a 350Z? Lots of parts are shared but I want to make sure before I sink $300+ into a wheel and quick release.
Well, there is a blank right above it in your car that looks suitable for mounting something. Or, if you always want to use the remote starter disconnect the factory button and either leave it unplugged (if remote works) or bridge the 2 terminals (if it doesn't work), then put spade terminals into the back of the factory switch for your kill switch.
Personally I have absolutely no idea re the steering wheel, mine is a C34 which is all rb compatible where your M35 is renault era
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
