hi guy is there any way that we can get some rwd stagea things going like tutorials and diy
What are you trying to do that you can't figure out?
Or do you just want people to spend heaps of time making tutorials on stuff that isn't required just on the off chance it might help you in the future?
  • 3 weeks later...
anybody know what the little steering wheel switch is for on a c34 s2 tiptronic auto?
Yeah it enables the gears to be changed via the steering wheel controls when the shifter is pushed to the left.
Edited by stock stagea
  • 9 months later...
  • 1 year later...
  • 7 months later...
How to repair seat switches in the M35 Stagea.
You MUST find someone with a proper, professional quality desoldering iron. The switches are pure copper and will suck up heat easily. Seat_1.JPG
Steps:
·        1)  Remove seat.
·        2)  Remove switch PCB from seat.
·         3) Remove switches from PCB.
·        4)  CAREFULLY lever switches apart (I used a Stanley™ knife blade), taking care not allow springs to end up 10 Metres away, by removing the switch cover.
·         5 Burnish and clean the switch contacts.
·         6) Condition switch contacts with De-Oxit™ or equivalent.
·         7) Allow to sit for a few minutes.
·         8) Clean off excess De-Oxit™.
·         9) Place a minute segment of Blu-Tack™ on the end of the two springs and re-insert.
·         Here is where you need 4 hands:
·         10) Place a loop of strong cotton (I don’t like using mon-filaments, but use whatever you like – it must be fine enough to allow the switch cover to be re-installed whilst the cotton is in place) around one end of the switch body.
·         11) Replace the two switch levers and ball bearings.
·         12) Install both switch actuators.
·         13) Ask you second pair of hands to place a second loop of cotton around the other end of the switch.
·         14) Both switch actuators should be reasonably secure at this point.
·         15) Replace the switch cover.
·         16) Cut the cotton.
·         1 - 16) Repeat as necessary for other switches.
·         17) Re-install on seat.
·         18) Re-install seat.
Happy days.
  • Like 4
  • 3 years later...
Just an outside chance it could be for 2wd operation if you have a 4wd but don't try it til you have read this:
hmm the below is for a C34 - don't know if it applies to your car....
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
I have hooked mine to a switch in the centre console.
On 05/07/2020 at 12:34 PM, LieutenantJiggles said:
anyone know what this "off" button is for? To the left of the hood release, under wheel. (2004 2.5L Turbo four)
That turns off the optional factory remote start system. Dealer fitted accessory, mine was mounted at the top of the driver's kick panel. Comes with about a mile of addition wiring under the dash too for maximum clutter
So it is important if I have an aftermarket starter, was thinking of putting my kill switch there. Also, do you know if a Stagea's aftermarket steering wheel is the same mounts/adapters as a 350Z? Lots of parts are shared but I want to make sure before I sink $300+ into a wheel and quick release.
Well, there is a blank right above it in your car that looks suitable for mounting something. Or, if you always want to use the remote starter disconnect the factory button and either leave it unplugged (if remote works) or bridge the 2 terminals (if it doesn't work), then put spade terminals into the back of the factory switch for your kill switch.
Personally I have absolutely no idea re the steering wheel, mine is a C34 which is all rb compatible where your M35 is renault era
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
