It wasn't me. The HICAS did it. :rofl:
It appears that the only damage that will require $$ is the rear bumper. The skirts need to be re-fitted and a bit of polish should sort out the rest.
For anyone that is interested, the data logger has confirmed that Michelin Pilot Sports max out at about 1.1g. :D
Edited by clayoth
  • Replies 160
Posted Images
Budge I hear you mate, and I bet there are few who put their hands up for commitee jobs because of it. Tell you what, ditch 'em and come join us, just leave the Superman suit behind.
What don't you need to have a Skyline to join the club? else why call it Skyline Club, may as well call it Wang Club or something like that.
I can help there Clayton, still have 2 R33/34 kits reserved for Wangers only but as I suggested, the brake balance may be the culprit....
Get matched rear calipers and master cylinder and sell the old calipers to Matt (R34GTT) and both of you will then have good matched brakes. ABS can cover a lot but not all the issues of mismatched brakes.
No you don't need a 'line to join, just a certain appreciation...right guys???
C'mon Budge, tell 'em........... to get stuffed and bring the good ones too :D
All those pics and not even 1 of my car :)
LOL...now you kjow my pain. No one ever takes pics of the R32 :O
Though i thought with all the bling on your car there would ba a few photos. Then again, balck car, night, maybe they just didnbt turn out
..oh and found the car i need to buy for this years Mod RWD class :(26gtstengine.jpg
Its an R33 but i think i can make an exception and own this GTST :)
I'd like this pic the best  :wub:
Pic
managed to keep the fire breathing Godzilla behind until half way down the straight
Hahaha - nice photo Hung.
Keeping Jack behind you and all with only 3 wheels on the ground!!!
This ones pretty good too. Pic
Hi, yeah that's my car - first time I've had it on the track.
Was very happy with the day as nothing broke or fell off.
It's a heavy dunger though - I still have 2 secs to find to get down to my Sti times.. :)
Cheers
Andrew
Very impressive, just wondering how long the rear bumper bar will last with all the flame throwing actions.  <_<
Will have to ask Geoff!!!! He's an expert at flame throwing......
It's a heavy dunger though - I still have 2 secs to find to get down to my Sti times..  :unsure:
Cheers
Andrew
Good stuff Andrew, looked like you were having fun, oh and don't worry, TEH GTR CAN NEVA LOSE! (except when driving in motorkhanas, especially blue R34GTR's.... :) )
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
