  • Replies 77
Posted Images
Incomplete car list as i don't have details on the Mitsubiushi crew that are coming down.
BAII FPV Super Pursuit Ute
FPV Tornado
Ford XR6T
Subaru WRX
GTR Nissan Skyline (530rwhp)
Mitsubishi Evolution VIII
BA GT-P
F6 Typhoon
RenaultSport Clio
Nissan Skyline Gtst 1995
Holden LX hatch torana
nissan bluebird attesa
r32 gtr 1993
’98 SUBARU WRX
GTiR
R32 GTR
N15 SSS
valent charger / mx5 turbo
VZ SS Ute
VZ SS Ute
S13 Silvia
VY SS ute
Silver Subaru Imprexa 2000 [MY 00 WA]
s15 200sx
Honda CRX (not type R)
R32 GTR
Great event, nice to meet ant and see some Skyline action on the track. There should be a link posted soon for all to see...
Too bad about the rain, noone could improve their times. Most fastest laps either 1st, 2nd or 3rd lap out.
Yep good to properly meet you Tom. I did enjoy Barbagello despite trying to learn the lines in the wet and dark :huh:
As Topaz said unfortunately it started spitting during the drivers briefing and never cleared up. The first two sessions were run with a damp track (just a light cover of rain) but after that it got properly wet.
Managed 7th fastest overall with a 1.04 in my 2nd session which ment I was 2nd quickest out of the 2wd which I am pretty happy with considering it was my first time out there and the conditions of the track.
Anyway I can't wait for the next event and believe that with a properly dry track and more experience I'll be able to crack the 60sec mark.
Fastest was Craig Hall -- VZ SS Ute -- 1m02.4301sec
I spun once on the last corner, just clipped the slippery APEX, but learnt my lesson after that. The best line is totally different in the wet compared to the dry. Lots of spins throse the S's by the RWD cars.
Hahaha yeah gotta stay off the kerbs in the wet as the paint makes them very slippery. Funny thing was that it wasn't the rwd spinning the most (well except for the utes :( )....lots of oversteer moments but they managed to stay pointed in the right direction. The most people that were spinning were the fwd boys....those magnas and that crx spun a fair few times. I heard the owner of the turbo'd magna comment that his was 'a fair weather car only' LOL :huh:
Again, a great turnout of the skylines so thanks to you lot! Was good fun learning the new race line in the wet. Just a shame my car was crapping itself and fouling plugs.
I guess I'll see you guys next time :)
For the record I had no problems with over-steer :(
Hi Guys,
Was a great night even with the bad weather and i was very happy to have the R home in one piece with out missing a beat, with the motor so fresh (2,500kms old) only ran actuator pressure all night NOT that i could of used anymore power hehehe was slipping drifting everywhere BUT never put a wheel off thank god and ran careful 1.04. The instructors were excellent and i used the night to learn lines and pick there brains as my experience is all dirt track racing (very different).
I look forward to the next event hopefully by then i will have some semi slicks or r comps and dry track so i can lean on the old girl.
pete
Pete, Not going to stick with the Federal tyres ? lol
Was a great night, even though I was only spectating, hope to be out there with you for the next one.
Cheers
Paul
Federals are not for the track for sure, i felt more like i was back on the stick clay at Claremont lol Time to put some nice rubber on my spare rimes.
Topaz i was in the white r33 gtr
pete
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
