1992 R32GTSt with rb20det at 140,000kms
4sp automatic
170.4rwkw @ 13psi
mods:
- rb25 turbo (series 2 with nylon compressor)
- HKS cam gears: inlet and exhaust
- walbro fuel pump
- 3" split dump/front
- 3" high-flow cat
- 3" cat-back
- boost controller 14psi
- high-flow air filter in stock airbox
- rb26 cams
- some kind of chipped ecu, not sure exactly what has been changed - this was done before any of hte mods
- FMIC with custom piping
- auto tans cooler
- 2800rpm high-stall (MV automatics)
- stage 2 shift kit (MV automatics)
Dyno graph below
1991, r32 GTS-T
Walbro
POD
Turbotech boost controller @ 12psi
FMIC
On DR Drift's dyno got 135.8 kilowatts. Was really lame, most of the 31's at the place beat me and to make it worse, he said my car was running perfect
Need...New...Turbo...
New turbo on so
Walbro
POD
Turbotech boost controller @ 14psi
FMIC
R34 NEO turbo
Remap by DR drift
460N.M. Torque, 170rwkw was highest run, dropped down to 167 because @ 170rwkw it had some minor detonation.
Pretty happy, hitting full boost at 4200rpm, fangs hard through to peak at 5800rpm, comes onto spool at about 3krpm
Edited by r32 gts-turbo
1992 r32 gtst
198.7 RWKW
707.7 N.M Torque
15psi
mods:
- trust tdo5/o6 turbo
- turbosmart 45mm external gate, with screamer
- 3inch to 3 1/2 inch exhaust
- front mount
- 040 fuel pump
- malpassi reg
- safc 1
1989 Type-M coupe.
stock AFM
stock fuel pump
stock injectors
stock turbo running around 0.85 bar
3 inch Xforce turbo back exhaust
JJR intercooler 600x300x76mm
KN pod filter
home made cold air intake
142.7rwkw on Dr.Drifts dyno at night at about 15 deg i reckon.
happy with that for minor mods.
1990 R32 gts-t 43000kms
R32 gtr fuel pump
Z32 afm
rb25 turbo s1 (leaking from compressor seal, pretty shagged)
monsta performance FMIC
apexi power intake pod
3" turbo back exhaust
blitz DSBC spec-r
dr drift dyno tune
156rwkw @ 1bar
Edited by salad
HKS GTRS on RB20 in R32 GTS4.
215rwkw at 18psi.
Mods are the usual:
HKS GTRS
HKS Type-S intercooler
Z32 airflow meter
Nismo 555cc injectors
Full 3" exhaust
K&N pod
Dr Drift remapped stock ecu
Bosch 040 fuel pump
Dr Drift boost controller
BTW: BP ultimate is way better than Optimax! :whistling:
The dyno chart shows the difference in response compared to my old R34 GTT highflow. You can see at 110kmh I now have 50rwkw more than before, which is an amazing difference in drivability on the street >_<
type m 32 gts-t.
3inch trust turbo back, stock cat
walbro 450pump
300zx single turbo huffin 1.1bar
apexi air filter,
trust fmic
made 196.something rwkw, then we backed it off to a better torque curve and made 192. something rwkw, expected e.t at the drags ??????.i would post dyno printout, but i duno how lol
List of engine mods
Apexi air filter
Z32 afm
FMIC
3' dump to 3.5' cat-back
GCG Hi-flow turbo
GTR Injectors
Bosch 040 pump
Sard FPR
Spitfire coils
Turbo smart 38mm gate with screamer (14psi springs)
Turbo smart E-boost2
I asked Glenn at hyperdrive for 300rwhp and after along run pissin around with things here's the result... happy boi, its really not as laggy as the dyno run makes it out to be!
1989 R32 RB20det 4spd Auto
115000kms
mods.
K&N panel filter
stock rb25 turbo
r34 side mount cooler
3" combined dump & front pipe
3" hi-flow cat
3 1/2" Jasma from the cat back
$22 boost controller 12psi
SAFC-1 tuned by HITMAN
219RWHP
1990 R32 Gts-t
95,000 kms
stock turbo, injectors etc..
FMIC
Pod
3" Turbo back exhaust, hi flow cat, 3" viken muffler
turbotech boost controller
bosch 040 fuel pump
ecu remap by dr.drift
14psi
169.2rwkw
no dyno pic as yet
comming soon
1990 r32 gtst
stock turbo, internals etc.
stock ecu
dump pipe
3inch exhaust
stock cat
k&n pod
stock fuel pump
no tune done that i know of
13psi
165.5 rwkw
very happy with it soon im going to remap ecu and get a bigger fuel pump
Edited by burnsie
1992 R32 Gts-t
Stock Turbo, injectors, ECU etc etc
HKS Pod
3" Exhaust
Crappy intercooler (backyarder -> From japan :P )
Turbo tech Boost controller -> 9psi
And very recently installed Bosch 040 (Today :))
= 150.6 rwkw
171.3 RWKW @ 11psi
Standard RB20 Bottom End
RB25 Series 1 Turbo
Turbotech Boost Controller - 11psi
DrDrift Remapped ECU
R34 GTT Sidemount
3" Turbo Back Exhaust (very quiet/restrictive)
K&N Pod Filter with Heat Shield
Walbro 255 l/h Pump
D2 Fuel Pressure Regulator
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
