1992 r32 gtst
std internals rb20det
std injectors and ecu
garrett ball bearing t04 turbo with internal w/gate
hybrid fmic
3" mandrel bent custom exhaust from the turbo back
de-cat pipe
turbosmart gated bleed valve
HKS pod filter
alum. pre-turbo intake pipe
oil catch can
gtr fuel pump
made 232.2 rwkw at 18 psi
since that dyno i have added a malpassi rising rate fuel pressure reg. but yet to check results
Edited by lagmonsta32
1992 r32 gtst
hybrid fmic
de-cat pipe
HKS pod filter
oil catch can
gtr fuel pump
Hey buddy, going off your results maybe my dyno sheet was correct?
My run Down:
1993 r32 gtst
ball bearing VG30 turbo
hybrid fmic
bleed valve
pod filter
walbro fuel pump
Adjustable FPR
made 221 rwkw at 16 psi
(i thought it was too much power for small mods i had)
Here you go Roy, dyno sheet.
not 100% happy with the curve, it could probably get brought on a lot better with fine tuning etc. BUT it does feel awesome through the hills!!!
Nissan Cefiro
RB24DET - Tomei pistons / tomei rings / tomei 1.2 HG / rb25 crank and rods i think (or rb26)
HKS 2530 / screamer pipe with straight pipe through to twin flutes at rear / Power FC / Gizzmo IBC / GTR injectors / Z32 AFM / walbro pump / GTspec FMIC / K&N filters / Motul oil / oil cooler
240rwkw @ 1.17 BAR
Edited by huddy
-R32 GTS-T 1993 RB20DET
-STOCK INTERNALS
-STOCK COMP & INJECTORS
-3.25INCH STRAIGHT THROUGH ZORST
-FMIC 600 - 300 - 75
-HYBRID TURBO 57 COMP - 63 ZORST INTERNALY GATED
-APEXI SAFC II
-EARTHING KIT
-Dyno results 151.4rwkw running 8.7psi at 5400rpm injectors maxed out and run was aborted
-will fit gtr injectors, sard regulator, bosch or walbro fuel pump and start turnin up the boost
to somthing that people don't laugh about
  • 4 weeks later...
1990 R32 GTS-t - 47,500kms
RB25 S2 turbo
Monsta FMIC (cheapest I could find)
GTR pump
3" turbo back
Blitz DSBC
Pod
Z32 AFM (not needed yet, but it's on there for later)
Remapped
182rwkw at 6600rpm on 14psi
Full boost by 3300rpm
Made a bit more power before (186rwkw) but did a few consecutive runs to iron something out and everything got a bit hot.
Edited by salad
184 rwkw untuned on 1 bar at turbo tune today
rb20det
4inch zorst
aluminium intake
nismo reg
hks ebc
hks pod
std turbo
fmic
then remapped by speedlabs only made 176 as my 185 was unsafe lol
go the stok turbo haha ( must be stok turbo record )
dont have scanner to put chart up !
'92' R32 GTS-T 123,000kms
Mods list:
Custom inlet plenum with belmouthed runners
Q45 90mm infinity throttlebody
Series 5 550 cc injectors
Gtr fmic
Gen111 5.7ltr fuel pump
Apexi power fc
Apexi avc-r
Apexi intake pod (mounted in fron bar)..... shithouse in the wet - great in the dry
custom s/s highmount exhaust manifold
custom s/s dump pipe with bellows for heat expansion
Garrett 3540 turbo
Tial 38mm external gate
S/S exhaust
Z32 afm
S13 RB20DET Silvia
3" High flow exhaust with split front/dump pipe.
STOCK RB25 S1 Turbo
Hybrid FMIC
R32 GTR Fuel Pump
Platinum NGK spark plugs
Remapped STOCK ECU (Tuned by Yavuz @ Unigroup Engineering) made 199.5 rwkw! :P:P
3rd gear looses traction on boost in a straight line! haha love it... GO THE RB20's!
Edited by s13rb20det
'91 R32 RB20DET 85.000kms
Stock Internals
Stock Injectors
Stock Computer
Stock RB25 S1 Turbo
3" full exhaust/screamer
FMIC
POD
HKS EBC
040 pump
Sard Fuel regulator
189.2 @ 1.1 bar (boostworx)
Edited by Richo
1993 R32 Skyline
RB20DET
Stock internals
5-speed manual
R33 S1 turbo
Trust front mount intercooler
Full exhaust (Split 3' dump/front pipe)
GTR fuel pump
Boost controller at 14psi
Re-mapped ECU
Air pod
Dyno'd at Tilbrooks Auto & Dyno
193 rwkw
AFR: 11
Edited by lows_13
R32 Skyline - RB20DET
Sliding Performance RB25 Hiflow for RB20
RB20 turbo wastegate
BOS importing split dump/front pipe, 3" meatalcat, 3" stainless catback
TRUST tube and fin FMIC
GTR 444cc injectors
GTR fuel pump
Remapped factory ECU by me :)
turbotech boost controller
NGK copper plugs gapped to 0.8
Splitfire coilpacks
Splitfire panel filter
Stock cams, airbox, BOV,
18PSI non shootout mode done in 4th gear on 30deg day
if you look at the sheet the scaling from rpm starts at 800rpm??? so the ramp rate looks ridiculous. didn't notice till after i left the workshop :P pretty happy with the results. it made 241rwkw a few weeks earlier but i cant find the sheet. Might put a exhaust cam gear on and see if i can get it to come on boost earlier.
  • 3 weeks later...
stock rb20 det
fwd faceing plenum
custome high mount turbo
38mm external gate
vlt3 exhaust housing t4b front cover 56mm comp wheel[built by myself]
std injectors
modded std computer
8300rpm limmiter
boost cut
speed cut
3''mandrell bent exhaust no mufflers no cat
made [email protected] degree day 40 in the shed!!!non shoot out mode
450*300*80 cooler
sorry no pics tuned by TOTAL AUTOS IN HUONVILLE HOBART TAS
Stock RB20DET
Highflow R33 Turbo
GTR Front Mount
Apexi SAFC II
Bosch 040
Standard Injectors
Malpassi Adjustable FPR
Apexi Pod
3" Turboback Exhaust by Desynz
Cooler Piping by Desynz
Manual Boost Controller
Tuned By FIST Performance
264HP on 14PSI
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
