  • Replies 40
Posted Images
This is what the one from APC looks like.
The difference is that this looks like it is meant to be there and it is apparently identical to the GREDDY manifold but takes the standard injectors (not standard throttle body).
That APC one is looks no different to a Greddy Plenum!
I'd say it is a greddy plenum!
Edited by B33st
call them
http://www.apc-racing.com/
this one is cheaper (around $700) than the greddy (around $1100) and i am told that the greddy wont take the standard injectors because of where the fuel feed is where this one will.
All i want to know is if someone has used one of them, if they have had any problems and if they have had good results.
Edited by R33NT
hi guys could you help me out i'm stuck over here in the uk freezing my arse off i've been following this thread with interest as we don't have anyone in the uk that does manifolds could someone post links up to the manufactures website cheers guys
yeah i run the plazmaman plenum on my rb25. It seems to work well, with very very quick throttle response and no lag.
I don't think i have quite that power that the other one on the dyno has..
But i've only got cooler', pod, and cat-back. :blink:
That looks exactly the same as the GREDDY as you said, can anyone confirm that it is THE SAME plenum without the name logo and the expensive price tag?
I have seen it, it isnt a GREDDY and it is not that expensive but i want to know performance.
I was told by APC several customer cars ran this plenum. I guess they could be VL's but i was hoping for a couple SAU members.
Edited by R33NT
Are you sire you cant use a std fuel rail with the Greddy? I know of one that uses a std GTR rail, adn he is only using that so he can use the injectors, so if the GTR rail fits the std manifold and the Greddy, then i say the Greddy would have no problem with the std RB25DET fuel rail
Bont Blitz make an apaptor these days so the RB25 can run a complete RB26 inlet and throttle bodies...much better option in my eyes considering the price that the std GTR goes for
Yeah they do, but it costs about the same (1000+) as the greddy manifold
The GREDDY rb25 plenum still uses the standard fuel rail.  Fitted on mine with no problems.
ahh, cool. Dunno where i got that from then.
These APC ones look pretty good for the price. If i wanted more than 300rwkw, then id consider to buy one :P
std injectors and rail fits these plenums
Which is what i said back here about std rail and injectors... we ran a std RB25DET rail on a mates car with GReddy plenum and i am running top feed RB26 injectors on mine, it just depends on which injector seat you use (there is a step down in the plenum to suit each injector)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
