If he was smacking the field about winning most races with a massive points lead I could possibly see him retiring but he's been fighting for the last few championships and I don't think he's about to give up yet.
F1 will be rather dull without MS that's for sure!
  • Replies 1.5k
Posted Images
Kovalainen replaces Alonso
Having confirmed Giancarlo Fisichella as a 2007 race driver last June, Renault announced this morning that current test driver Heikki Kovalainen, 24, will race alongside him in 2007
looks like Raikonnen is off to Ferrari next year... its a pity, would have loved to have seen him in the same car as Alonso to see what they could do against each other. Still, that one less piece in the jigsaw puzzle. Bring on Monza!!
yeah, it should have been webber fisi, or webber kovalenien. either way I'm still reeling from the fact that webber could not put together a deal at renault. even with his manager running that team. I reckon he has once again been screwed by flava flav.
the only, and i mean ONLY, reason i can see why Renault kept Fisi is to help kovalenien get adjusted to the car for race weekend setup and technical info guidence... but thats a pretty weak argument...
i think he kept him cause of the whole "will renault continue in F1" debarcle a few months back. All the second tier drivers we either gone, or going to other teams already and Renault must have though that keeping the team stable with Fisi was the best option. Webber would have kicked his Roman ass all year if they snapped him up
Edited by ctjet
He will announce his retirement at Monza :D
I like Melbourne later in the year to-gives the champoinship time to settle before it gets here :)
told ya-MS gone :)
Go Ferrari FTW
Edited by gtr660hp
a sad day for F1. I'm very sorry he didn't do a final year farewell tour next year. that would have been great, and would have gaurenteed sell out crowds at every F1 race on the calendar.
let's hope he can seal up this years WDC and leave in style.
a great man, and a great racer. Certainly in the top 3 drivers of all time. 7 (8?)WDC will never be replicated in my life time.
:D
I can't beleive that I missed the race. I haven't missed one in years, but I just completely forgot it was on last night.
Probably good that i didnt stay up to watch it though as i was already tired and was up at 4:30am today.
:(:(:D MS leaving, I read it at 4:30 this morning when I woke up, and was upset...then I saw he won last nights GP, and that Alonso had a DNF!!!! that makes the gap 2 points now?!
If he has to retire this year, I hope he takes the title on his way out!
Benm: Upload the entire race for me please ! lol
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
