Well there are alot of second generation drivers around at the moment.
Rosberg.
Senna.
Piquet.
Scheckter.
Locally:
Jones.
Johnson.
Moffat.
Plus alot more. Guess some of them must have some talent. I mean, the statistical probability means that atleast one of 'em could drive out of sight on a dark night. Surely. Ok, maybe not.
  • Replies 1.5k
Posted Images
what a knuckle head. how could he say that? It's like saying if schumacher had one less leg he may not have won any titles. fact is mate, your uncle did die, and MS did win 7 world titles. get over it!
baron for president.
What an absoulte tosser...so he's basically saying that his uncle would have won the exact amount of championships that would see he and MS level on 5 each?
:thumbsup:
I think what he was saying was that Senna in a Williams in 94 & 95 would have been a much better proposition than Hill & others in the same car. To which you would have to concede he has a point.
Also, Senna would have retired after equalling some bloke called Fangio in the number of championships. Atleast according to Nigel Roebuck he would have.
Whether or not Senna would have beaten Schumacher is another issue & one not worth the argument. So nobody start anything & we will all get along fine. :thumbsup:
add brabham and brock to the above list.
you know who I like? Kubica. next Michael Schumacher I reckon.
Which Brabham - there are three of them, Geoff, Gary & David.
Also Brock (& for that matter Jones) are resapectively a step child & adopted.
I forgot to add the Davison family, although the latest generation seems to be doing quite well.
Steven Richards disproves the rule, also.
For next year I would put my house on the Finnish bloke. Don't mean Rosberg, either.
Edited by djr81
nah, Kubica all the way boys. mark my word. Pole will be on Pole soon enough.
I was thinking David Brabham I have NFI who the others are!
and yes Richo JR is good, but damn he has a head like a half sucked mango.
I forgot to list some bloke called Glenn Seton.
Geoff Brabham won Le Mans with Peugoet in 91 & did alot of racing in the US.
Gary Brabham won the F3000 championship in 1989.
Don't go the blood nuts, Baron. They can really angry really quickly....
They used to have an award in the Can Am series. It was for Polish drivers. It was the Polish Pole Position Pole. Unsuprisingly the trophy was a, um, pole.
By the way did anyone wathc the reply of the '78 Australian Grand Prix on ABC 2 on Sunday? The laps by Fangio in the old Merc & Brabham in the BT were just gold.
That's it. Great stuff. Later on in the fottage you can see the touring car mechanics lining the pit wall to watch. They followed it with edited highlights of the Hang Ten 400 - Moffat, Bond, Johnson in XC Falcons & Brock, Harvey, Grice, Rogers et al in A9X Toranas.
Gotta be some of the best TV going around at the moment.
just came across this little piece of trivia
Alonso completed his entire championship-winning campaign... in one car. Chassis R26-03 took to the grid in Bahrain some seven months ago and the same car crossed the finishing line in Brazil. It did not miss a single race.
... thats pretty impressive
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
