wouldn't i go for bkr7es (or bcpr7es) for the colder plug? or am i getting confused?
Black soot would indicate a hotter plug is needed but you might not need to change the plug if gapping it down does the trick.
ahh yep i get it, so the plug is hotter to help burn off the soot, or another way, so its not a cool area in the cylinder for the soot to form on...
That is a dangerous game to play. I would say your plugs are sooty for different reasons, most likely just rich A/F ratios the car could be R & R'ing or could just have a rich idle (bung O2 sensor) or just be a normal rich running RB with upped boost.
If your car is in any way modified, I wouldn't recommend hotter plugs; standard 6's would be a minimum.
Edited by SKiT_R31
just changed my ngk coppers (bkr6es-11's) to bosch fr7dp's (equivalent to ngk platinums gapped at 0.8) and the car is now drivable again. the coppers died after 5000km and on the day i changed plugs the car was barely drivable. was very sad.
still missing problems every now and then but that'll be the coilpacks, they're desperate for a change
  • 1 month later...
I have standard copper BCPR6ES and the car misses a few beats at idle.
At higher rpms I could not detect anything unusual.
(running 14PSI)
Is it normal that the car misses a few fires at idle?
RB25DET
Thanks and sorry for being slightly off topic.
Cheers,
Andrew
(running 14PSI)
if you're really keen to make it a bit smoother do a search, it's a pretty common problem but most people just leave it. first things to do are clean the iac and aac valves, there are diy's on them in the diy section...
but as said above, it's pretty normal
miss at idle is usually the ignitor getting tired, pretty common
Thanks guys .. I was a bit worried about the pops at low idle.
And to contribute something to this thread:
I am using these V-Line Spark plugs in my Skyline (on the right)
VLine
NGK on V-Line
I have no idea if there is any advantage to multi electrodes, but on my motorcycle it really made a difference.
(though I don't believe in Snake-Oil :verymad:)
And here's a link from NGK with some videos included (technical advice on installation):
NGK
More:
Edited by Torques
i've had a miss fire problem for months and just assumed coilpacks. hadn't even thought to change plugs. i'll just go copper so that's BCPR6ES right? RB20 running 7 PSI?i drive fairly tame 70% of the time. i bring it up on full boost probably only once or twice every drive. so that means i should go a hotter plug? or doesn't it really matter and i should just get the bcpr6es?
go bcpr6es-11's cos it's stock boost. 6 is a hotter plug, 5 is recommended. have a read of earlier pages in this thread, plenty of answers there
After finally getting my FMIC return flow installed, it took me awhile to narrow down this thing my car is now doing. If you've ever had or driven a front wheel drive car with maybe old or spongy front shocks, you'd know the feeling when you are trying to floor it and hit bumps. The car kind of shudders a little and you can feel the traction slipping.
Now with my car I have a standard turbo running the ground boosting trick. What happens is when I put my foot down, there is for sure more power there, but there's also this feeling like the car is slipping or hiccuping. Could this be due to my Bosch Plats being gapped at 1.1?
I don't know where to start to go about fixing my problem, but at first I thought I was just imaging it, but after driving around more it's there for sure. Oddly I notice it more than I have the Overdrive ON. When it's OFF and I have the Power/Snow switch set to Power it still does it, but I think the increase in revs is helping to hide the fact I've got a problem somewhere.
So guys, where do I start to look at this problem?
5 is a hotter plug, 6 is reccomended. 7 Is a colder plug and is more ideal if running more than stock boost imo. Also, a 1.1 gap is fine providing your coilpacks are in good shape, but 0.8 are what your supposed to run and will give you the least issues (especially if your coilpacks are getting old).
It's common for a missfire to clear in the higher revs, its definitely your gap, i would down it to 0.8. If you still have issues you need to source some new coil packs - you can happily gap down to ~ 0.6 but any lower and you start to really hurt your idle and light throttle/off boost.
Ah ok. I still have my old Autolite plugs, so might clean them up, gap them to 0.8 and see if that cures anything. If it does, then I'll have a go at gapping the Bosch Plats. I don't want to damage them if it turns out it's not the gap, so the Autolites will be testers hehe.
bosch plats gapped at 0.8 are like $5 more than the 1.1's, well worth the dollars cos u dont have to risk damaging them
Where can you buy them from? I got mine from Repco or something for a 6 pack @ $38 or something. They only had the 1.1 gapped ones.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
