  • 1 year later...
:D
Sorry to dig up an old thread.
The pic above, will that be enough to provide decent cooling using the factory ducts and the deflectors mounted to the lower arms?
I've got the front bumper off my R32 GT-R at the moment, doing some mods and was wondering whether anyone cuts through the inner guard to provide more airflow into the wheel well using the two horizontal slots that are either side of the main intake opening on the front bumper?
I'm sure I've seen at least one fast R33 GT-R at the track use this method (used plastic mesh similar to what you put over a gutter to keep leaves out etc to go over the hole).
I've attached a pic showing where I am talking about. I tried searching the forum but found minimal info about this type of thing. I'm presuming no one really does it because it's not worth it?
Thanks mate, I've got the undertray ducts and have recently ordered deflectors for the arms. Looking forward to your solution! :D
Did you order Nissan deflectors or the ones from Unique Autosports?
It shouldn't be too hard to bash something together with aluminium plate & strap it onto the castor rod/LCA?
I cannot for the life of me remember if these ones are stock or aftermarket. The appear to have a couple of holes to use where the castor rod meets the LCA.
Edited by djr81
Wow this thread is old! since then I've bought a set of the genuine nissan caster rod reflectors, because I am limited to standard parts.
The ones that UAS make and similar are cheaper and better than the nissan ones.
Yeah sorry for that, it was either make a new thread or continue on with something that was kind of related to what I was after :D
DJR81, I haven't received them yet, will take pics and post them up once they arrive and are fitted.
Yeah sorry for that, it was either make a new thread or continue on with something that was kind of related to what I was after :D...
absolutely no problems, I love when someone searches and looks at what was said before instead of starting from scratch every time.
It was actually from this thread years ago that I found out that the caster rod deflectors are standard (n1) and so they are legal for me to run on the race car. I ordered them about a year ago out of japan (very hard to find and possibly nil stock with nissan now) and put them on. Can't really tell if they made a difference as I changed multiple things at the same time.
But locally made ones are larger and cheaper anyway.
the ones you pictured are the nismo ones for R32 GTR. they were fibreglass or FRP maybe, and were about triple the size of the stock ones. the stock R32 ones were rubber and are in that parts diagram posted above. I think the stock castor rod deflector ones were only on nismo 32s, v specs and v spec IIs, and N1s. but all cars had the ducts under the bar that bolt to the front lip holes.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
