I have also read that if you deck the block then 25/26 pistons work well .... is this true ??
What comp ratio do you roughly end up with when using RB25det pistons ?
Cubes and i are using Wiseco rb25det pistons in our rb30det. They decked the block (20 thou?), and added a 3 layer metal head gasket, and compression works out to around 9:1 if Cubes' calculations are spot on :)
Oil squirters are overrated. Do like SK says, ceramic coat the pistons etc if you run cast ones, or just run forgies and dont worry about it :)
Having a piston sit down in the bore is dodgy, because its supposed to end its stroke flush with the top of the block. Otherwise compression, squish etc are all off.
No one has mentioned about the rb26 head having larger head studs that the rb25. You need to retap the rb30 block out to bolt the rb26 head on.
  • Replies 286
I am still wondering about the SUMP adaptor, cant u just use the sump from the GTR/GTS4 on the rb30? U might have to modify it a little? Also is it ok to use a VL turbo headgasket with the 25de head? If not will an rb25det metal headgasket do the job?
The bottom of a RB 2wd block looks nothing like the bottom of an RB 4wd block. The 4wd block is much wider, has many more and much larger diameter bolt holes. As you would expect to hold up a big diff, drive shafts and large cv joints for the front drive.
:P cheers :P
Yes well i am a noob to this, so feel free to drill me all you like :P . Well if a sump adaptor has to be used then ill have to get one, the guy that sells these on the forum does he answer his pms? Its just i hope to have my motor finished by sunday and hence ill need the adaptor before i can put it in next week so id like to get it kind of soonish... Also how many are going with a custom plenum to solve plenum hitting bonnet problems? If you do modify the engine mounts to suit then wont the gearbox and everything else be out and be under a lot of stress, hence why i am just getting a custom plenum top $200 bucks let me know if anyone else needs one.
Sorry to ramble so much in the one post but i have a few more questions :P . Which turbo would be ideal for this motor Gt3540, injectors GTR 440's, Q45 TB and Q45 AFM? At the moment i have a HKSGT2510 which would make it more like a supercharged 25/30 :lol:
Edited by FOOLBOOST
ok, well i'll point out if you are doing the rb26/30 conversion, you would be using the rb26dett head, which already has the front facing plenum from factory.
gearbox etc, can be spaced down the same amount the engine is dropped, but ive been running my car without doing it with no vibrations, or problems.
Turbo, i suggest whatever power you wish to strive for with the supported mods. Gt2835r or upwards (gt30r minimum), and a longer diff ratio.
25/10 is way too small like my turbo. On boost its useless, just wheelspin.
The castings are slightly different, the oil gallery that the squirters have to be tapped into has variances in its diameter and the wall thickness varies as a result. I have found no common ground
Thanks SK, mystery resolved.
no I am not pullng it out of the car to take photos
lol ..... and why not ??? no help internet people of today :lol:
Cheers black32
I am suprised it works out so high comp wise as the extra CC in the head drops the comp a bit from what i understand.
Just to confirm you decked the block for the sole purpose that the pistons sit to low ? and not to gain comp ratio ?
Cheers black32
Cubes is the details man, more of a memory than i :D
Bit of iffy area about what our comp ratio works out to be, as the engine builder worked it out to around 8.5:1, but cubes says he worked it out to be 9:1. And going by somethings (like the amount of timing we run ?) he seems to think it may just be.
Hi all,
My adapter plate allows you to bolt the rb26 sump to the rb30 block. It is CAD designed to match the rb30 block to the wider 4wd sump. However there are other mods that have to be done besides just the adapter.
After that you will have to fabricate an external oil pickup due to the different pickup locations for a rwd rb series engine and a 4wd engine. You will also need to lastly modify the studs on the cv side of the sump to 2 long bolts, and also die grind or mill flat a part of the rb30 block to allow bolts instead of the studs on the diff side. This all sounds hard but i provide detailed instructions on how i did it and how you can do it, and if you are mechanical you can do alot yourself, I have done around 6 know and have sold many plates. This aside i sell the bare plates laser cut from cadium plated mild steel for $450, and if you got the rest done at a workshop it would cost no more that $4-600 in labour. So total cost is around the 1-1.2g mark, which is very competative considering RIPS will not do the job without selling you a built bottom end for $3800, and NIZPRO and AVO will not do it with out your own motor and sump sent to them and they charge $4200, theres is slightly different but I also offer different versions of tha adapter, however I am not bagging these workshops they do good work, but if you are a DIY'er then my setup is perfect for saving some money and getting involved.
If you have anymore questions please dont be afraid to ask. But i don't really want to give out pics and detailed instructions just yet when it took me so many r and d hours to work it out for myself, like i said the other guys that do the conversions wont even sell the plate seperate cause they dont want to give away secrets!!! But like i said if you have questions about the process of fitment please dont hesitate. The plate i sell is straight forword and guys out there could make one themselves but it takes time to get spot on, and most people would rather buy soemthing they know has worked ad yeah I am not in this to make money so i basically sell the plates for what they cost me.
Cheers,
Daniel
Oh and FOOLBOOST if you want to chat give me a call on 0418 327 427, not on the computer much anymore so dont get to check my pm's.
Guys i have now got a problem cant find an r32RB25de non vtec head, so looks like i will be going rb26 this will also solve the bonnet/plenum clearance issues. Was wondering what mods have to be done to the stud holes with regards to being smaller? Also will it be a nitemare to setup the inlet plenum throttle linkages and wiring to go to the rb26head? I am also thinking of going single turbo if i can get a single turbo manifold or is twins better would be much easier since id be getting the twin manifolds with the head anyway???
Have located an rb26 head with plenum and exhaust manifolds complete 1500 apart from injectors, cas and ignitor. Now can i just bolt on an r32rb26 head with mods to the bolt holes and use my gts4 injectors, cas and ignitor and power fc??? Then i will have to locate twin turbos or run a single if i can find a single turbo manifold!!
Ended up getting a complete r32rb25de non vvt head with injectors coil packs, manifolds etc $500. Have finished bottom end pistons and crank, just waiting on metal headgasket and head goes on. I have also just received one of daniels sump adaptors nice piece of work! Now all i will be left to do next is modify the bottom end to suit the 4wd and relocate the oil pickup etc does anyone sell these already done??
Edited by FOOLBOOST
Heads on, ran into the problem of the exhaust manifold touching the block, so have decided to grind the manifold down rather then the block. Also just bought a GT3540 with 1.06 rear AR hope thats not too big or i will be changing to .82 soon if its too laggy. Will be making a custom adaptor plate to standard manifold which runs an external wastegate along with custom dump pipe, ill post some pics up.
  • 3 weeks later...
My 25/30 motor is finally finished and there seems to be one thing i have overlooked, it says to grind down the webbing in the sump on the rb26 sump, since i am using a 10mm sump adptor plate will i still need to grind the webbing down?? I need to know asap as the whole motor is finished and i want to make sure the rods arent gonna hit on the bottom of the sump??
Edited by FOOLBOOST
i just got my RB26/30 engine back from my engine builder and was wondering what people do for oil and water feeds for turbo's, i am using a high mount twin setup if that makes a difference
rb20/25 sumps have webbing towards the rear of the them which has to be grinded down otherwise rod cap will hit, rb26 sumps dont have webbing so dont have this problem! What the hell do i do with the gearbox since the top 4 bolts line up but the bottom 4 dont any ideas??? Thinking of just using the top 4 and leaving the bottom ones out :D:laugh:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
