  • Replies 297
Posted Images
just get them hpc coated...come out nice and silvery...cheap and wont chip or scratch off as easily as paint. ive seen a ca18det and rb25 covers done. Around 40 bux to do a set of covers.
  • 1 month later...
hay man just wondering i have an r33 gtst and what do you need befor you take off the rocker covers is there any gaskets or seals you need to replace when you take the covers off and paint cos i want to paint mine the same colour as the car (marone)
prety easy.. i didnt take the fuel rail or any of the stuff on the intake side off..
just loosened it and pushed it to the side so i could get the back bolts undone... once they were loose i used a magnetic stick to pull them out, exhaust side is easy
so what went wrong?
I'm going to do mine next week, any advice???
I have bought some primer but havent choosen the paint yet! I can't settle on a colour....
they might just go back on black!!! hmmmm
toss up between Nur gold and R34 metalic red....
so any tips would be great!!!
make sure you clean the surface with metho or something that doesnt leave any resedue.. like electrical contact cleaner.
again clean the surface after primer before you paint.. sand the primer back and apply more primer till its heaps smooth.. then wet and dry it, then clean n paint
Mark,
I think the plenum is a wayyyyy to hard a job! I simply masked it up in place and found a similar black spray to touch up the few chips I had in the original paint... and it turned out good!
as for the cam covers! I am getting pissed with it, as the surface just isnt coming up all that flash!
I am about to give in, and go get the crinkle finish paint (like the red cover on the S1 R34 GTR above) and go with that, as it hides the imperfections far better!!!
and what he was talking about was the plastic fuel wiring loom cover (allen key) undo and push it away...
I also found the twin turbo pipe had to come off too...
if this doesnt work, I will admit failure and get a professional to do it in the future!
grrrr
Mark,
Hrmmmm. Cheers Ben. Mine has pretty much lost all the paint (bizarre for a *genuine* 70,000km car :) ) so it'll have to come off, because I'm going to bake the parts to cure the paint.
I shall see how I go.... (famous last words....) :)
Drew was it fairly easy to remove the plenum? Or is that what you were talking about when you said just loosen everything?
i dont think taking the plenum off just to paint it is worth the blood sweat and tears.
i just did mine because i have the enging out
And Sean some of that painting you've done looks very intricate! Did you freehand or mask? Parts like around "Nissan" and RB26 look very nice!
Cheers. I did it free hand with a fine brush and model paint.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
