Hey guys i want to paint the rocker cover of my RB20 but i dont know what kind of paints i should use. im guess i should just use a normal primer or a plastic primer (when painting plastic bits ie,cam cover) and then a heat paint.
has any one done it and if so can you post some pics cause i think me engine needs a nice tidy up.
thanks
  • Replies 297
Posted Images
Yeah I took 2 shots at with the spray on engine paint, then gave up and had it done in tupac.
You can pick up the engine paint at any car bits shop and ahve a go, it may be OK if you are going a dark colour like black, but it looked crap in yellow.
No primer required engine paint goes straight on bare metal
or try the metal cast paints.. there is a section in the DIY regarding painting brake calipers.. heat resistant and has a primer and colour application.
thats what i'll be using for my cam gear and spark plug covers. just gotta get off my arse and do it lol
http://www.duplicolor.com/products/metalcast.html
i painted mine rb20 engine cover blue with plastic primer paint came up a treat and my friend also painted his cover too in white also came up well, cant see any cracking or anything from the heat so its all good.
i tried using that shit on my cam cover, and the results were tragic. the primer worked a charm and actually looked really good, but once the blue metalcast went on, it was SOOO flat and DULL. it looked like absolute shit
it was pathetic. ontop of that, the design of the nozzle is so ingenious that the spray pattern is such that it actually clips the rim of the can when spraying, so as your spraying your creating this pool of paint on the inside of the lip on the can. my first can had a faulty nozzle and just leaked like crazy, i took it back to autobarn and they replaced it for free. tried again and it came out dull and shit again, i dont know if i didnt give it enough coats or what, i was up to 2 coats and a single can wasnt enough it seemed for a rocker cover..
after hours spent paint stripping it back to bare, i used 'engine enamel' from autobarn, no primer required, chose a gold colour, looks awesome. this is my experience :laugh:
  • 8 months later...
An old thread I know - but I just wanted to warn everyone about the Dupli-Colour metalcast (anodize) colours!!!
I too have experienced the very dull appearance of the blue one. If only I read this thread earlier.
Followed every instruction to a tee and had all surfaces preped perfectly (with undercoat etc). It looked like shlt - dull as, not even a metallic look to it.
But I do not think it is limited to the blue one as I have heard of a few others turning out dull - bad batches??
As I am a sucker for punishment, I gave it another go using red this time and it turned out perfect. Ironically blue was probably a poor colour choice in the first place as red looks the goods.
Anyway - if I had my time again I would go the powdercoat route - prolly works out cheaper!!
Here's a pic of the duplicolor red > cam covers, apexi pod adapters, and a few other bits. Also did the OEM strut brace - no more faded red (yay). nice chrome strut brace would be nicer but hey - gotta work with what you've got.
Just the coil pack cover to come and then I'll bolt it back on. knowing me I will scratch the sh!t out of them putting it back on and have to start again :wave:
Cheers,
Tay
nope it doesnt need to be out :wave:
Cost on having this sort of thing done professionally?
I imagine it would be 'fairly' cheap if a common colour was chosen.
e.g. if timed properly could use the 'leftovers' from someones respray
Possible?
Yeah its sort of tricky to do it IMO
If youre not doing the plenumn it would be easier
Its basically just some screws and unplugging the ignitor box - aswel as the cam gear cover
Get in there and have a look around the base of all the parts you want to spray at what holds them on - that will give you the best idea
Oh, you may need to take the crossover pipe off for a bit aswel so you can get easy access to the ignitor
Possible?
no idea what it'd cost to get 'professionally' done, i got a mate to do mine :rofl:
Im getting the rocker covers and the cross over piping polished chrome, and intercooler piping repolished as its not much more expensive to get that done aswell, And the plastic covers painted.
Just wanted to know when u removed the rocker covers did u need a new gasket or anything as i haven't removed them on my car before.
If so how much was the new gasket or could u re-use the old one?
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
