***fave Chillhood Comp/arcade Game***
  • Replies 88
Posted Images
Heroes Quest on the PC before they renamed it and made it point and click.
That with Leisure Suit Larry, Bit of Duke Nukem and some old Super Mario Brothers stole a fair bit of my childhood!
Ooooh and Scarab of Ra. Surely some other old Mac fans might know that one :)
nba jam playin with big heads :)
after burner was mad fun in that moving aircraft thing.
alex kid in miracle world was sick, you just close the cover of the master system and it plays hahaha, didnt need a cartridge.
captain comic on pc ownnnnned. i loved that on the 286s. instead of fire balls it used to shoot out asterix's ;) aahhh the memories.
all the street fighters were awesome.......
damn they should have like a timezone from the early 90s where you can go and play all the vintage games, that would be so much fun
captain comic was the SHIT!
Ooooh I don't know how I could have left Doom 2 off that list!!!!
So much old skool awesomeness.
Double-barrelled shottie was my fave weapon. BLAM!
Need For Speed Special Edition... That was awinner... Ripping Helis in the ol' Dodge...
Or maxing out the Lambo on "City" stage one at 202KM/H
I miss the old NFS series - the video clips that they used to have (can be found on YouTube now). And yeah I loved the point-to-point courses for variety as opposed to just racing circuit layouts all the time.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
