Looks like the resolution of bluetooth devices is inherently unaccurate and will not allow anywhere near good enough timing for track events in the way I had envisaged with using your mobile phone integrated bluetooth. ;)
BUT, there is another nearly as good solution I am testing at the moment that has said to have millisecond accuracy. :)
The ONLY downside is that it will cost about $55 dollars for the in car hardware to buy from me once off to be able to use the system. :D
I will be testing the "TurboClub Track Timer" as it is to be known as, at the moment and will report more soon.
Previous entries into TurboX's BLOG recorded below...
QUOTE(TurboX @ 27 Feb 2006, 04:16 PM)
You would think that in this day and age with so much electronic and computer WiFi stuff around cheap that it should not be to hard to come up with some ideas on how we could make this a reality.
Anyone like to think about this as I am sure its not too hard...
Guess I have to reply to my own post as no-one else looks like they are going to
OK - since asking the question, I have come up with the ANSWER!! At virtually NO COST!
Works like this -( I wont bother to patent this as it's just too obvious )
Drivers Mobile Phone (MUST be BlueTooth Enabled)
Some ones Laptop -ANY -
TurboClub Track Timer Assembly & Software - Donation to SAUVIC by TurboClub.com and City Notebook Centre - 8 Market St. Melbourne, www.CityNotebookCentre.com.au
I will say I am going off a bit half cocked -so to speak, here - but the concept seems sound and the proof is not far away - stay tuned.
Guy's, I have been working on the track timer and its looking good but the resolution looks at this stage to be only within the second.
For example Phillip Island 1:48 (- I wish!?) No tenths or hundreths possible -YET;-)
What do you think Snowman? Do you need more resolution to make sure Chris is not close enough?
UPDATE***
OK - consensus is that it NEEDS to be 1 /100ths.
It looks like this is a problem with Bluetooth as the Hardware/Software does not have the capability to resolve to anywhere near this level which is a pity as using the drivers phone had a lot going for it in terms of ease of use and deployment.
I do belive that 802.11 has millisecond timing capabilities but the logistics of deployment in the competing vehicle make it harder unless everyone has a laptop!
AND I am not going to lend them out to everyone
I am sure there is a solution somewhere though just have to think of it.
https://www.sau.com.au/forums/topic/109582-turboclubcom-track-timer/
TurboX how is it that bluetooth restricting you in 1/1000 of a second, cuz am finding it hard to figure how exactly ur goin abt this from ur post.....am intrested to know wut ur main concept is aswell as if u do have a sketch or graphical representation of ur concept....wud be easier to understan.....
I am doin a masters in networking n specliase in wireless communications and wireless application development, while my cousin just graduated from electrical engineerin....so both of us are intrested to understand ur concept.....
Not exactly the type of people he would want to share his design ideas with :D.
With your qualifications you should be able to design your own.
Interested to see how this works out, beats taping a stop watch to your steering wheel! :woot:
Just one question, will it enable the driver to see the lap times as they reel them off or will it just record them trackside?
If it happens the way I want it to, it will send the lap times to the drivers phone each lap as well as recording automaticly to the laptop.
The Bluetooth system is not good enough to resolve the actual timing functions but it will allow transfering the times to the drivers phone if he has bluetooth enabled. - you could tape that to the steering wheel hub ;)
The actual timing will be done with another wireless system that has the 1/100 of a sec capability, and I am working on this at the moment. :P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
