Electrically operated valves.
I’ve been waiting for these since I was a kid, and that’s along time ago.
So what’s the hold up? Formula 1 engineers had a toy with the idea and Mercedes actually has an engine running.
The enormous tuning options are only limited by our imagination.
Just a few:
No cam shafts, timing chains, lifters, rockers etc, etc.
Engine starts decompressed, builds oil pressure then the ecu kicks in some cylinders.
Valve lift, duration and timing all adjustable via the ecu.
Vary the engine capacity by partially filling cylinders to offer a smaller capacity for light load, idle situations.
Completely drop off any cylinder at any time, the mind boggles at some crazy firing orders.
Real engine braking, make the Jake brakes on the Kenworths look twice.
With the fanfare of GM’s “new” olloytec engine and Ford strapping a turbo on their twin cam head, all technology at least 10 years old, where are all the lateral thinkers?
https://www.sau.com.au/forums/topic/110009-electrically-operated-valves/
This would just give manufacturers another reason to f*ck car modifiers in the arse. Notice that it is starting to get a lot harder to modify cars these days because of more and more electrically enhanced products?
An example of this was when the XR6 turbo came out. There were/are measures to prevent turning the boost up too much. It is a complicated issue to fix, which most people have got around by engine management computer modifcations.
You can get around these measures by aftermarket development, but as manufactures get more clued up as to how to protect their development, a lot more work needs to be done by the aftermarket companies to catch up. Hense the price of developing products to overwrite the manufactures settings will be passed onto the consumer.
Edited by Thunderbolt
Would the gains over a well designed multivalve, variable valve timing, variable valve lift engine make the enormous increase in development costs worthwhile? Imagine how much software development would need to go into programming such a thing?
Has been and is still being tested but it needs a Power system much greater than 12 volts.
More like a 48 Volt system and the Current draw on the much larger required alternator to keep the system running puts a massive drain on the engine negating the power penefits gained by not direct driving the Valve train from the Crankshaft.
Works in theory but expense and lack of real world practicality will see it delayed until other problems are overcome.
The valves use a solenoid actuation but with much more control than a conventional on off solenoid.
F1 already use pneumatically actuated valves because a normal cam shaft wouldn't be able to keep up as I understand.
The big determining factor is cost.
The bean counters are the ones who run companies these days.
Doesn't matter if it's a quasiturbine, rotary, 2-stroke, 4-stroke, they all have a valve or port of some sort and that's one of the first areas that gets modified when you're trying for more power.
Incidentally there are a few patents pending and of course they don't use massive voltages, solenoids etc. Mostly electro/hydraulic and are capable of operating well within the range of conventional engine RPM's.
As for developmental costs, have any of you seen how complicated a sleeve valve is? Check out a Bristol Centaurus.
  • 3 months later...
It's not the camshaft that can't keep up, it's the speed at which the valves have to operate that is the problem. They open and close so fast you get valve float. To stop this you have to use stronger valves springs or dual springs. This becomes a game of diminishing returns as revs rise so do spring resistance , sapping power to open and close the stiffer springs ,etc Ducati and earlier Mercedes use Desmodromic valve operation. This system doesn't use valve springs but levers off the camshaft to positively open and close the valves. Pneumatic valves just use air or N2 for springs
Rota whatta whatta?
What are these fandangled things you speak of?
:P
The next BIG step will be rotary valves in the everyday engine. This kind of thing makes camshafts and valves obsolete. Once the bugs are ironed out that is.
just google "rotary valve engines" for some good examples.
rotary valves on one of these.
(just trying to up the ante. Don't care much for counter rotation, but more power al all rpm + a higher rev limit...)
and although the how stuff works article implies it, I don't think there has been a working prototype of an internal combustion quasiturbine engine.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
