I understand everything about this concept but I have never seen an RB26 motor out of the bay before...does anyone have any pictures of where these oil feeds are.....and how do you differentiate between which is the 1st feed and 2nd so as not to get confused aboiut which to block and which to restrict?
Thanks
I wounder how this effects oil pressure just by blocking the rear orifice off.
cheers
Makes no difference, the pressure relief valve controls the oil pressure.
:dry: cheers :thumbsup:
I dont really want to pull a RB26 apart just to do these mods, especially given its young age (1999) but i dont want to sit back and wait for it to go 'BANG' while im at Mallala.
Would a much larger sump with the appropriate baffles suffice for the occasional track day or does the majority of oil remain in the head regardless of sump volume???
snake you pretty much have to pull the engine to put the baffled sump in, the head is only a few bolts further to go....and once thats off why not do new rings bearings and balancing as well?
Ok Guys...
On sunday we started pulling the engine out to do
1: restrictor
2: clutch
3: Engine mount
4: look for any issues
5: change lifters
We took out the engine and box at the same time.
I have got pictures here for everyone to look at on how to put the restrictors in. its pretty easy and does work!!!! before i used to get lots of oil escaping from the CATCH can. ie the catch can was not working. now nothing comes out of the catch can. All i did was block the front oil feed and put a tomei 1.5mm restrictor in the rear feed (as per sydney kids advice) people would tell me my engine was rooted because its got lots of blow by rah rah rah so i aimed to prove them wrong.
To block one of the oil feeds we screwed a screw into the 1.8mm (stock rb30 restrictor) and then pulled it out. once it was out we realised that the screw was stuck in there so we just cut it and put it back in. (See pic)
As for the other one I purchased the 1.5 mm restrictor from hi octane (the tomei one for $17 delivered) and bashed the old restrictor down and bashed this one ontop. (see pics)
for the million $$ question does it make a difference in oil pressure???.
YES.. it does.. BUT only when the engine is cold. before the oil pressure gauge would go up to 3 quarters full on cold startup. Now it goes nearly up to the last line but as soon as the engine warms up it goes back to normal and NO oil pressure increase has been noticed at all.
No difference in lifter noise has been noticed.
YES it did fix my problem (well SO FAR. no oil has escaped from the catch can when before it would escape from catch can.)
I built this RB30DET back in 2004 before anyone knew about the oil issue and how to fix it - so thanks to sydney kids help i have been able to fix this problem.
Its very easy to put the restrictors in and i reccomend that you do this on your rb30det conversion.
See pics.
I hope this helps everyone - heaps of pics to look at.. I am really stoaked my clutch works properly now !!! :mellow:
Edited by Guilt-Toy
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
