Is there a reason why the rear head drain setups always seem to go to the turbo side of the sump? I'm just about to weld on my -10 fitting for the head return and the intake side seems more logical due to less heat and the fact that the sump baffle isn't in the way of the high position on the sump.
Save yourself the trouble and forget about the "rear head drain". There is no evidence that it does any good at all. A couple of fittings in the sump are a good move though. Read the thread and all will be revealed.
I have read the thread/s mate. I believe the rear drain is a must for my setup and there is more evidence to suggest it is better than not having one.
You read the thread and still think it's a drain?
Actually it is a little bit relevant to the question.
Initially when this mod was done years back - it was definitely thought of as a drain foremost, and a breather second.
The reason it was taken to the turbo side of the sump was because it was thought the rotation of the crank causes a slight vacuum on that side, helping to draw oil down the drain.
It was later argued that under heavy acceleration (when you need it most) that the oil would never flow 'forwards' from the back of the head to the front of the sump.. and then later people considered it worked moreso as a breather.
I used to run the back of the head drain and have since removed it.
Instead I have vented the Intake side of the sump, up to a catch can. This still 'breathes' but not back to the head, and then from the head to the catch can... just straight to the catch can.
Does that answer your question?
Don't talk sense and logic!
PS. 32 coming to Powercruise? I missed out on forklift torque ride last year :(
Anyone with RB's have issues under hard braking on the track?
Oil is overfull, larger sump, catch can all sorted and working well etc etc but under really hard brakes i am bringing the oil sender warning on? A few have said they suffered similar.
Options to bandaid it were an Accusump type setup possible?
Also, oil pressure drops at idle after a long session on the track. Recovers as soon as revs are applied and runs pretty much where it should throughout the rev range.
When I didn't have my oil issues sorted and I was getting too much oil in the catch can I was getting a small issue under brakes (luckily not much load so didn't cause any issues... yet *touches wood*) but since I've got it all worked out I've got no issues at all.
Oil pressure drops at the oil temp increases and gets thinner so after thrashing on the track it's not uncommon to get less oil pressure at idle.
  • Like 1
Should I have said 'breather'?
Get over it, I had the choice to type either word and the term is irrelevant to my question.
What evidence? If you know it all already then why come in here asking.. U called it a oil drain cause that's what you thought it was.. Don't get all tied up around the axles if you learnt something.
I myself use to think it was a oil drain, until one day I pulled the hose off and there was bearly a drop of oil in the pipe. Then I did some research and discovered it acted more as a crankcase ventilation. So don't waste your time with these fitting.. Just hook your cam cover breathers to a catch can and run another fitting from your catch can to your sump higher then your oil level.
Worked fine for me
  • Like 2
Ive got the Same problem with My 34.
Under Hard braking aswell. Pressure drops to about 20 psi with the rpm still around 4.5k
Only has a stock sump , but most of the aftermarket sumps only really allow for oil surge during cornering
What Brand of sump are you using
So what's the problem? 20 psi with no load? Presumably pressure climbs as you accelerate out of the corner...
Bump
1.1 or 1.2mm restrictor for an rb26 with some track/ drag/ street use?
Seriously? There is so little difference.
Disclaimer: I sell 1.0, 1.2 and 1.5 so no 1.1
Cheers for the lesson. Didn't realise that 1.1mm and 1.2mm where very close in size..
The reason I asked is cause the chart listed early stated 1.25mm for street, 1mm for drag/circut.
I plan on doing all 3 of the above tasks and thought a 1.1mm was a good inbetween spot but wasn't sure if a 1.1mm restrictor would cause any issue's on the street.
I have a 1.1mm and a 1.2mm sitting in front of me.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
