Finally finished reading this topic... exhausted now.
If I was to completely change my current setup on my RB26, I'd now go with the two sump fittings on the inlet side as high as possible, as mentioned lately.
But it is a single turbo setup now and the rear turbo drain has now been utilized to have a braided line from the rear of the cylinder head as a breather (not cyl head drain as its advertised everywhere as), sure the fancier catch can with more fittings sounds like it will work, but my catch can setup as it is, sits behind the passenger strut tower and takes both rockers covers into it, along with a drain line into the turbo drain and a vent line into the turbo intake.
Nitto oil pump and 1.5mm restrictor, having read more, I'd probably go a 1.2mm now, but I'm happy with how it has been setup by the previous owner, so i'll be keeping it as it is for now, and this is a street car, not a track car, and having made 400kws without any oiling issues evident so far, i'll keep it as it is.
If I rebuild the cylinder head in the future, then I will tidy up the oil drain ports, and if it visits the track, then I will be monitoring it a lot closer.
Need advice. Can anyone here tell me how my catch can is supposed to look inside?
Baffles?
I have buildt it, and just spot welded it together and made sure it fit the car before going into the next stage. So I have to take it apart to do the inside. But I do not know how it is supposed to look.
The bungs is AN12 x 2 from rockercover. AN10 x 2 from crankcase breathing and AN10 x 1 as a optional return line to sump.
Its meant to be baffled inside. If you Google you might find some images but basically the incoming flow should hit a flat plate surface first and preferably more than one to encourage the moisture (oil/water) to precipitate...drop to the bottom of the can...so that only hot gas leaves the can. A crude way is to fill the can with stainless steel wool.
Here's some
https://www.google.co.nz/search?q=oil+catch+can+baffles&biw=1700&bih=1037&tbm=isch&tbo=u&source=univ&sa=X&ved=0CBsQsARqFQoTCIqzlITOsscCFQEtpgodbKAAIQ&dpr=0.95
A genuine rule of thumb is air/oil to flow a minimum of 180deg. With my catch can i did something similar to the pic below (sorry phone drawing haha). Basically air/oil comes in and hits a flat plate, has to run down then back up through steelwool then back down (2x180deg now) then back up through steel wool.=3x180 in total and 2x separate steel wool sections. The baffle that runs right to the bottom i had a couple holes so it could all drain out (not big as didnt plan on draining to sump)
is it best for the sump return to be on the same side of the divider as the filters?
Yes if you have a non-return valve in it. No in my case because my two sump vents both act as breathers until the can starts to fill with oil then only the top one is a true breather while the bottom one does provide some pressure relief. I guess three lines, two to the top of the can and one to the bottom as a dedicated drain is theoretically better but in practice my two line system with no non return valve has been fine.
"Filters" are illegal in most cases and I don't have one. My outlet goes to the turbo inlet pipe and if there was any evidence of oil getting in there I would put another air/oil separator in that line but there hasn't been a problem
OK, so, have the rear head drain/breather but am trying to decide where to connect.
Twin turbos on a dirty 30.
was going to go into the rear drain line, but reading g this, as a breather it wouldn't work.
the engine is together, so drilling and welding a port is out of the question.
Should I just connect the way I was?
leave it?
other suggestions?
Yep.
filled the head with oil.
was on the track at the time.
didn't have the drain on then though.
If your head is filling with oil the fitiing at the back of the head will do SFA wherever you send it. Have you done anything different such as fitting restrictors? If not its engine out and head and sump off.
Several option before doing that
from my experience you can put the head "drain" as you called it, Teed into the 2 turbo drains and all drain back to the block ASLONG as you let the intake side of the sump breathe well!
I ran this setup on my DOHC single turb 30 and never had an oil issue flogging its guts out.
2x -12 sump breathers intake side
1x -12 head drain to ex side of block with -10 turbo drain teed into it
2x -12 cam cover lines
both sump breathers and cam covers ran to the baffled and vented catch can, NO return line to sump (e85)
6.5L sump
2L accusump
1.3mm restrictor and 1 blank
tomei oil pump relief capped to 110psi by 5000rpm.
do what you wish with my info, tell me im wrong, tell me im right, it is a very reliable setup.
6.5L sump
2L accusump
It should work since you've shelled out for an accusump!
The restrictors and sump breathers will help.
Yes you "can" put in the "head drain" and you "can" paint flames on the mudguards but neither will do anything useful.
In most cases vented catch cans are illegal so I'll give you 8 out of 10!
  • Like 2
So as some may have seen ive been staying tuned to this topic as i like this thread.
I have been experimenting with different setups as i build a few rb"s
On rb26 ive gotten pretty much sorted out. I started with the piston rings. Next was head oil restrictors. A custome head drain. (Ok not a drain lol ) so bare wit me a bit here as im sure ill get ridiculed. I vented the block from the front turbo drain unsing a dash 10 hose. Head drain (not a drain) to the rear turbo oil drain. And the singal gt42 drian go to the race fab oil pan on the turbo side. I have 2 rb26 set up this was and not a signal sign of oil. On the rb25's its a bigger challenge and ive done the following that seems to work upwards of 28 psi of boost and no sign of oil the car doesnt even have a catch can at the moment as were being lazy and not installed it as yet.
We really realized that the rb25's shouldn't have there oil restricted to much as the lifters need to have a good amount of oil. We even had some new set make noise untill they cooled down. Before that the just failed and tick all the time. Were talking new lifters from rhd japan here. So last what seemed to work for us was to get rid of the front head drain. We blocked that off from the head and vented the block but we focused on really letting all this oil drain. We had no idea if it will work at the time. I puched the biggest hole i could in the back of the head with 2 dash 12 (drain) hoses one on the intake side of the head to the front ofna race fab oil pan, exhaust side on the rear of the oil pan. The standard head drain pooled the oil in the line and backed that up in the rear of the head. So we thought we should pool.the oil in a oil catch and use the weight of the oil to help puch it down only when it pools up. Whiles cornering it would do so in the respected dash 12 drains. So this led us to make our own head drain. ( please remember this was all experimental at the time.) So after that was done the turbo oil drain was returned in the same place as the rb26 set up. But on the rb25 there was no oil drian as on the rb26 for rear turbo. So we simply made that in the block. And from our dash 12 hose (head drain) exhaust side we returned it there.
The photo i have a ruff but gives a good illustration of what i mean. The photos are old and missing the 2 dash 12 hoses.
But we have been testing it and not a sign of oil as yet. If anyone is intrested id be happy to give more details. Just pm me.
Yeah the outside is bad. The inside is good and clean. plus after is gets dipped. Then it comes out like new. By the way thats my first week of using a tig welder. Lol
Marcus, how are you connecting that nasty looking rusty steel box to the huge hole in the alloy head?
Lol
Thats funny. I punched the matching hole in the back of the head. In the first photo you will see it. Like i said its all was experimental
But seems to work. I will remake them all out of aluminum soon as i dont have a good tig welder. And its not a ac/dc high frequency unit. So i was stuck with making it out of steel
Im suprised at how well it works. Trust me mate. The finish product looked way better and turst me when i say there no rust on the end unit.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
