Lol
Thats funny. I punched the matching hole in the back of the head. In the first photo you will see it. Like i said its all was experimental
But seems to work. I will remake them all out of aluminum soon as i dont have a good tig welder. And its not a ac/dc high frequency unit. So i was stuck with making it out of steel
Im suprised at how well it works. Trust me mate. The finish product looked way better and turst me when i say there no rust on the end unit.
I'm not convinced that your steel box is the answer. There is a theory that much of the spewing out oil problem is to do with correct fitting of rings (not so much with RB30s where the crank action is suspected of much of the problem) and maybe that is how you have succeeded.
However if you have no problems well done.
BTW most engine installations I have seen don't have much room for a steel box (rusty or not) in that position!
Yes i agree. Its fits perfectly. I do agree with the rings part. But as the motor ages we will see. But comparing to other setups at high boost levels i would see signs of oil. I wouldnt install rusty box to flow oil through as that would defeat the whole point. I feel from all of my test that the spool head drain doesn't work to well it just gets pluged and all it is, is a nicely shaped peace of aluminum with literally a hole drilled in it. I feel the oil pools and builds up faster than it can drain and blocks the factory ports. It gets more complex in cornering g's.
I have been messing with all sorts of ideas over the past year or so. Buy pooling the oil lets say in this rusty old box here. The weight of the actual oil helps to drain it back way way more efficiently. Rather than having the same idea happen in the head and overwhelming the factory hole by the last to rearward head bolts. This thing works like a water fall and frees up losts of breathing. One big down side we had was gear box swaps the engine couldnt tilt any so we had to drop the subframe till we got the box to fit then lifted it all in place. It was a pain but using a car lift the second time worked well. The benefits really out way the extra work. I do agree also with the additional stuff mensioned here as well. Properly picking the right size restrictor vs oil pump and rpms. Crank collar or newer crank. Exstended sump with good trap doors baffle. As well as good venting high above oil level. I found the rb25 to be a tougher at doing this. Without starving lifters of oil. So we approached it abit different.
Edited by MJTru
  • 1 month later...
Talking about blowby and catch can set ups....I was wondering how the Integrated Motorsports R34 GTR and Steve Ka/Powertune R34 GTR got rid of the bleeder hoses coming off the valve covers? Makes the engine bay look a shit load cleaner. I know the JGTC rb26dett's were very similar, so my guess is the dry sump oil system. If anyone has some info or other ideas let me know.
  • 5 weeks later...
as my thrashed car gets older i have now added a accusump and activated the external scavenge
which has made the oil pressure awesome one left handers however its now blowing oil out the second catch can breathers
so i have now added a one way -12 valve to the front catch can to stop oil being pushed up the drain
will report back if awesome or not!
I ran my set up right up to 8800rpm at 2 bar (740rwhp) around the track with sticky R-comps the other night and not a drop out of the catch can.
This is with no oil restrictors to the head and a stock bottom end, venting the sump works
  • Like 4
So would you say an easy improvement without tapping the sump would be venting through the dip stick?
Edited by XGTRX
I don't think the dipstick tube compares with two half inch vents.
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
