If your numbers are all the same except for one cylinder the chances are you have a problem with that one cylinder - ie #6.  So yeah have another go at a compression test but dont be surprised if you have an issue particularly if it is spitting oil.
Edited by djr81
3 hours ago, -S- said:
So i hesitated to post due to no backed up facts but anyway I just did a compression test and these were the numbers. Stock motor.
P1 - 200
P2 - 200
P3 - 200
P4 - 190
P5 - 220
P6 - 190
And I'm still filling up my catch can easily. .. can i conclude that its just too much oil to the head? Initially i was worried it was due to piston rings ... any thoughts on this? But I'm sure glad the numbers were ok...
What do you mean filling up the catch can easily? You mean with normal driving or on the track?
If you have broken rings on one cylinder that will do it. Try another compression test and preferably a leakdown test.
Yes filled the can on hard driving. .. man... this sucks... i guess I'll try another compression test else where or order the kit and do it myself. .. :(
You just need a cheap gauge. Does it blow the dipstick out?
http://www.ebay.com.au/itm/Nice-Portable-Auto-Motor-Engine-Cylinder-Pressure-Gauge-Tool-Compression-Tester-/152311279791?hash=item237675b0af:g:2SsAAOSwKOJYIpT5
or Supercheap or Repco etc
  • 1 month later...
Does anything speak against this setup:
-Hose from right cam cover to catch tank
-Stock Hose from left to right cam cover
-Properly baffled Catch tank vent to atmosphere
And here comes the part I didn't find anything in this thread:
-Hose from AN10/12 fiitting from sump (above oil level on intake side) to existing left cam cover connecting point (which normally goes to intake before turbo).
Should do the trick same as going directly to the catch tank, am I right?
So I can use the existing port on the cam cover, don't need to modify my catch tank and it is a really high point (maybe less blow by than going directly to catch tank)
1. Venting to atmosphere is illegal on public roads and also sub optimal as venting the catch can to the turbo intake can create a small amount of vacuum which helps to vent the sump.
2. It is better for blowby to go to the catch can because the baflles can take out some of the oil.
3. The optimal setup has two hoses going from the sump to the catch can - one to the top and one to the bottom. The latter can act as a drain to allow oil from the catch can to go back to the sump.
4. You don't mention oil restrictors - did you fit any?
There is of course no absolute right and wrong but the above worked for me and a number of others. Some say that a properly built engine will not have oil control problems but RB30s in particular are prone to them.
Engine is getting rebuild right now. Will add a Tomei Oil restrictor.
No track days at all. Only Street driving. Only a few kilometers per year. Don't see any need for a drain back to the sump, will empty it if there will ever be a drop of oil in it.
Didn't had a catch tank at all before and had almost no oil consumption, but will make the engine bulletproof this time. I don't wanna do it again.
Quote
Main question is, will this work as good as going directly from sump to catch tank? Should not make much of a difference?
Edited by GT-R David
Oil control is usually only a problem when at WOT for a decent length of time such as long straight on the track or extended dyno pull so for a street car you may not experience any problems. Restrictors are a good idea if you have the engine out already.
I used to have a pretty blowy motor, then I read this thread and hory shet the difference was extreme. What I had previously (even with the stock 1.2mm restrictors in the 34) was in the photo. Would get this kind of stuff after any real kind of RPM's happening.
Blocked one of the feeds, and had the drains enlarged as the head was off at the time. Prolonged revving later (as in.. probably hours of it) and maybe 20ml in the catch can. Enough that it wasn't so much oil as Oil + water vapour, greeny sludge at best.
(I got a fitting for my sump but looking at whats IN the catch can... wouldn't want that going back down there)
In any case, just sharing my experiences with this thread and the help it provided!
  • Like 1
Main question is, will this work as good as going directly from sump to catch tank? Should not make much of a difference?[/Quote]
No one has a answer for that?
I guess this means nothing speaks against this solution :-/
Thanks for the link! Was going to ask . Guess u read my mind. And no my dip stick never blows out.
Just thought I'll add...My catch can is connected via the 2 rocker covers--> hose to catch can and vented out.
Cracked ringland on the 6th for sure. Exactly the same problem I had with mine.
Unfortunately is engine out and rebuild time
Hey guys great artical about oil restrictors in rb engines. I have a series 1 rb25det I just put in the tomei 1.5 oil restrictor in the middle oil port and blocked off the back one all together my concern is will my hydraulic lifters still be getting enough oil with the rear one completely blocked off and the middle one restricted? Any info would be greatly appreciated
Thanks
Thanks
Yes
  • 1 month later...
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
