Right
the short story
rb26 det (ford xr6t) 1 bar of boost 291rwkw (stock injectros)ill put up the graph but full boost at 4k
unblivebly drivable and im very happy
read the story below if you want teh ful story as why the big injectors didnt go in
adam say with 20psi and the bigger injectors should cruze 330-340rwkw but i must say im happy with it for the moment. he also said it should do a low 11 or a high ten so now i can officially be a massive wanker and say in all my post 10 second potential..... lol.... even though ive never ever been to a drag strip
Here is the rap for Adam at JEM now….. we dropped the car of at 5pm he quoted for 2 hours on the dyno) in the end we left at 3am in the morning with a car that was just shockingly fast (and the sound is awesome) total price was 200 bux more that the initial quote. Adam when so far beyond what a workshop I would consider even remotely reasonable. Great to chat to and a good bloke. If first impressions are anything to go by the dude is a champion and I wouldn’t hesitate to recommend him to everyone in Australia
If you need your car tune he is the man and I must say I never though my car could go that fast on a safe tune at 15psi
Long Story
Ill give ya the full run down this is a 10 hours dyno story of mystery... smoke and mirror. Tits. Booze women and 4 hairy block with huge donggas.
First up a massive plug for Adam at just engine management JEM (I cannot begin to tell you haw far ken good this dude is he stayed up till 3am with us and sorted all the issues)
Right I got there at 6pm last night to find Chris who had put the 660 cc injectors into the beast and the rb25 airflow meters on first start up with a miss in two cylinders
Right so after 20 checks we decided that obviously 2 injector were crapped because the when we put the stock ones in the car ran fine.
So that brings us to 8pm put the car on the dyno attach all the stuff boost fuel pressure adjust the timing ECT
Turn the car on suddenly we realise something is amiss because the fuel pressure reg (which is adjustable) the lowest adjustment we could get was 100 psi so we tested it in front of the reg and behind the reg and deduced that there must be a blockage \in the return to the tank. Turned out to be on of the surge tank fuel lines was kinked (the return one)
So that was fixed
Now was about 9pm anyway Adam ripped it up on the dyno and the car made 240rwkw at 7psi nice but up to it just wanted more fuel and the fuel pressure gauge said the bosh pump was running out of flow or just shagging out so we tested the wiring and had a good earth and good positive anyway we replaced the pump and same dram and she was apples so then we tested the fuel filter every sign line form the surge tank to anywhere for a blockage
We even hard wired the positive onto the pump no luck
In the end we tried the in tank pump and she was good for pressure so we nutted out it was either the wiring on the external pump or by a freak coincidence two dead pump
So next we wired up the pump straight (positive and negative) to the battery with a switch
So final call was the earth from the computer which runs on a relay was shagging out or the power source from the wiring was breaking down under high load
Yea baby full pressure any way in the end because it was 3am and the tune had just finished and we only worked out the problem we only tuned the stock injectors 300rwkw and pulled it back to be safe to 291rwkw at 15psi.
The car used to run 280 rwkw (in tank pump) and was fast
Now the car at 291rwkw is just far ken amazing all boost is in at 4k the power is just crazy it makes 230+rwkw from 4k onwards
It’s got so much grunt it’s almost scary to drive
That’s my story
No vids of burnouts cause we left at 4am and I couldn’t be farked although in third when it comes on boost i does pull a mean high speed skid
Edited by fatz
yea i was hopping for 2nds so im happy
yea in the 31
shame we didnt have time to tune it with the 660cc injectors cause then we could have had some arse puckering power
havent event touched the cam gears yet either(rather spend time adjusting the pro lojics in the sound system)
Congrats man, thats sweet....The more High HP R31's the better!!
Just got 425hp out of the 31 but full boost is not till 7000. 4000 is insane. It truly is Godzilla's daddy!!
G
Edited by GT-PASSAGE
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
