  • Replies 234
  • 3 weeks later...
900 was just the basic unit, so basically i'm only controlling air/fuel right now.
ok unigroup dyno in shootoutmode
catback - 152rwkw
full exhaust & apexi power intake - 164rwkw
emanage - 174rwkw
I'm still running about 11 AFR's, so still a tad rich.
Car feels alot better all round :)
i didn't track fuel consumption before/after.
No it can't remove the 180 speed limiter.
stupid question but wich motor r you running this formula in .and do u think i would be better of with one of these units 15psi
  • 1 month later...
Anyones thoughts?
As long as they have catered for the SII ignition coils then I don't think these would be a bad idea...even if they haven't it would only take a few minutes to fit the 6 diodes.
doridori32 - Great to see you're the first person to post a completey irrelevant comment in a technical thread!
Never read the first post :D
I just have a question. I am currently working on a r33 gtst. It has an aftermarket Greedy turbo unsure of what size, 550 cc injectors, and an e-manage greedy piggyback system. I can not get the thing to run. When I do get it started all it blows is black smoke(rich) and eventually floods itself out. Does anyone know of anykind of airflow settings that I could possibly try inputting into the system? If you have any information please e-mail me. Thank you. :flamed:
Have you changed the correction value in the main setup screen to suit the bigger injectors? That shold be enough to get it running but it will still need some tweeking in the Airflow adjustment map and additional injection map to have it running properly as different types of injectors flow different amounts at the same duty.
Cheers
Dave
Not trying to sound patronising, but does it show 0.673 in the correction factor...ie you've got the injector sizes the correct way around.
Also make sure you upload the file, or it won't take effect.
I upgraded injector sizes and it worked fine...before the factor went in I had black smoke too...it's the only thing it can be?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
