  • Replies 234
I remember 666Dan last time only used the injector harness and not the ignition, therefore he had no problem with the coil pack.
I was under the impression that the coil pack only goes with the ignition harness installed.
I think the fuel control is fine.
I also have heared from the Yahoo group that the 1.36 firmware have corrected this problem. Is this the new firmare you are talking about Abo Bob?
Last time I spoke to Dr_Drift, he mentioned something about signals interference somewhere from the ignition harness to the auto ecu and this was what causing the problem. I think that's what he said? It was a while ago :D
  • 1 month later...
Hey guys, no I'm still not using the ignition harness. BTW just for your information, GReddy are releasing car specific harnesses that just plug in, meaning no soldering required for the ignition and injector harness, as it's a premade unit that goes between the ECU and factory harness.
I just don't understand why it could be a problem to use fuel control but not ignition control.  Heaps of people use SAFC's on autos don't they?
I was sure I answered this a few posts ago ................
The big claim for e-manage is that they work for autos in piggy back with the standard ECU. This is OK for fuel, but the auto shift problem with ignition timing optimisation seems to have been ignored, or maybe it is simply too hard to program.
Yep, thought I did.
Maybe further explanation is required.
In the autos on gear changes the ecu retards the ignition, this both smooths out the gearchange and lightens the torque loading on the gearbox. If you put an ignition interceptor (e-manage) between the ecu and the igniters this means that the ignition won't be retarded on gear changes. So you will get flaring and damage to the gearbox over time.
In order to work on autos, the e-manage would have to have some extra logic in the software that worked out that a gearchange was happening. Then it would allow the ignition signal from the ecu to pass through without changing it.
Since Apexi haven't bothered (and/or been able) to program this logic into Power FC's (no PFC's for autos) I don't see it happening for e-manage any time soon. But maybe I am just being pessimistic. I hope so, ‘cause the Stagea will be here in 2 weeks.
Just thinking out loud.
As the emanage has no cas input it is really ony dependent on intercepting the outgoing signal from the ecu and delaying/advancing that (i assume to advance it actually is delaying the signal by almost one cycle). So when the auto shifts the stock ecu will retard the timing to waht it normally would plus the amount of advance the emanage is putting in so the timing is still being retarded to a certain extent.
Or no?
Or no?
Could be wrong, but I think not. I don't believe the E-manage adds X amount (of retard) to the standard ignition timing (as varied by rpm of course). I think it chooses the timing all on its own, as per the tuners input. Otherwise you could only have retarded timing, not advanced, as it wouldn't know when to fire because the ecu wouldn't have told it yet.
Did that make sense?
Thats what i mean by firing late enough so it's actually early for the next firing stroke.
Say when you start the car piston 1 is on the firing stroke, ecu sends signal to fire the sparkplug but emanage intercepts it and does not send it until the next firing stroke on cylinder 1 but slightly earlier in the stroke so its effectively advanced. It's about the only way i can think of that the emanage can advance the timing because you are only adding advance to the standard timing, not re writing the entire ignition map.
Either that or it is using the signal of the first cylinder that fires to adjsut the advance on the next one that fires.
Trust actually state an error of +/-1 degree in their manual for ignition timing which i assume is because it is not using a cas but using the firing signal from the ecu as it's input.
This is why i think it should still be retarding on gear chang in autos. Or i'm completely wrong about the whole thing and it's actually really simple.
You'll have one in two weeks SK ;)
Good timing Bob, our Stagea arrives in two weeks, but it won't be complied until 10 days after that, plus a couple of days to get to Sydney and then it's rego time. :D
anyone interested in buying a Gtech, dont get ripped off and pay $399
can supply brand new in box including freight Australia wide for $160.
Call Darren on 0417898512  [email protected]
Is this a spam attempt? Or did you just forget to post in the forsale section.
  • 3 weeks later...
Hi all,
Been running an E-manage on a RB25DET for a couple of months without any problems. Got round to wiring in the ignition harness today and the engine runs fine, no E-manage fault codes but the ECU flashes 21 which is ignition related I believe. Tested for fault codes prior to fitting the harness and it read 55 - all clear.
Funnily enough I got this code on my CA after fitting the ignition harness too.
Does anybody else get the error code when using the ignition harness ?
Also is anybody using the new add on detonation sensor harness for the e-manage ?
  • 3 weeks later...
OK guys read something interesting relating to the use of the e-manage on the RX-8 apparently the OEM coils get fried by the e-manage as well...this can be countered by using what looks like a zener diode setup....see the link below. It prevents the continuous powering of the coil-pack.....so only the peak signal voltage will pass through the diode (firing signal)...the holding voltage is below that of the diode trigger so doesn't pass through and put the coil under continous load. The theory seems sound to me.
http://www.rx8club.com/showthread.php?s=&t...&threadid=17055
  • 3 weeks later...
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
