  • Replies 234
I remember 666Dan last time only used the injector harness and not the ignition, therefore he had no problem with the coil pack.
I was under the impression that the coil pack only goes with the ignition harness installed.
I think the fuel control is fine.
I also have heared from the Yahoo group that the 1.36 firmware have corrected this problem. Is this the new firmare you are talking about Abo Bob?
Last time I spoke to Dr_Drift, he mentioned something about signals interference somewhere from the ignition harness to the auto ecu and this was what causing the problem. I think that's what he said? It was a while ago :D
  • 1 month later...
Hey guys, no I'm still not using the ignition harness. BTW just for your information, GReddy are releasing car specific harnesses that just plug in, meaning no soldering required for the ignition and injector harness, as it's a premade unit that goes between the ECU and factory harness.
I just don't understand why it could be a problem to use fuel control but not ignition control.  Heaps of people use SAFC's on autos don't they?
I was sure I answered this a few posts ago ................
The big claim for e-manage is that they work for autos in piggy back with the standard ECU. This is OK for fuel, but the auto shift problem with ignition timing optimisation seems to have been ignored, or maybe it is simply too hard to program.
Yep, thought I did.
Maybe further explanation is required.
In the autos on gear changes the ecu retards the ignition, this both smooths out the gearchange and lightens the torque loading on the gearbox. If you put an ignition interceptor (e-manage) between the ecu and the igniters this means that the ignition won't be retarded on gear changes. So you will get flaring and damage to the gearbox over time.
In order to work on autos, the e-manage would have to have some extra logic in the software that worked out that a gearchange was happening. Then it would allow the ignition signal from the ecu to pass through without changing it.
Since Apexi haven't bothered (and/or been able) to program this logic into Power FC's (no PFC's for autos) I don't see it happening for e-manage any time soon. But maybe I am just being pessimistic. I hope so, ‘cause the Stagea will be here in 2 weeks.
Just thinking out loud.
As the emanage has no cas input it is really ony dependent on intercepting the outgoing signal from the ecu and delaying/advancing that (i assume to advance it actually is delaying the signal by almost one cycle). So when the auto shifts the stock ecu will retard the timing to waht it normally would plus the amount of advance the emanage is putting in so the timing is still being retarded to a certain extent.
Or no?
Or no?
Could be wrong, but I think not. I don't believe the E-manage adds X amount (of retard) to the standard ignition timing (as varied by rpm of course). I think it chooses the timing all on its own, as per the tuners input. Otherwise you could only have retarded timing, not advanced, as it wouldn't know when to fire because the ecu wouldn't have told it yet.
Did that make sense?
Thats what i mean by firing late enough so it's actually early for the next firing stroke.
Say when you start the car piston 1 is on the firing stroke, ecu sends signal to fire the sparkplug but emanage intercepts it and does not send it until the next firing stroke on cylinder 1 but slightly earlier in the stroke so its effectively advanced. It's about the only way i can think of that the emanage can advance the timing because you are only adding advance to the standard timing, not re writing the entire ignition map.
Either that or it is using the signal of the first cylinder that fires to adjsut the advance on the next one that fires.
Trust actually state an error of +/-1 degree in their manual for ignition timing which i assume is because it is not using a cas but using the firing signal from the ecu as it's input.
This is why i think it should still be retarding on gear chang in autos. Or i'm completely wrong about the whole thing and it's actually really simple.
You'll have one in two weeks SK ;)
Good timing Bob, our Stagea arrives in two weeks, but it won't be complied until 10 days after that, plus a couple of days to get to Sydney and then it's rego time. :D
anyone interested in buying a Gtech, dont get ripped off and pay $399
can supply brand new in box including freight Australia wide for $160.
Call Darren on 0417898512  [email protected]
Is this a spam attempt? Or did you just forget to post in the forsale section.
  • 3 weeks later...
Hi all,
Been running an E-manage on a RB25DET for a couple of months without any problems. Got round to wiring in the ignition harness today and the engine runs fine, no E-manage fault codes but the ECU flashes 21 which is ignition related I believe. Tested for fault codes prior to fitting the harness and it read 55 - all clear.
Funnily enough I got this code on my CA after fitting the ignition harness too.
Does anybody else get the error code when using the ignition harness ?
Also is anybody using the new add on detonation sensor harness for the e-manage ?
  • 3 weeks later...
OK guys read something interesting relating to the use of the e-manage on the RX-8 apparently the OEM coils get fried by the e-manage as well...this can be countered by using what looks like a zener diode setup....see the link below. It prevents the continuous powering of the coil-pack.....so only the peak signal voltage will pass through the diode (firing signal)...the holding voltage is below that of the diode trigger so doesn't pass through and put the coil under continous load. The theory seems sound to me.
http://www.rx8club.com/showthread.php?s=&t...&threadid=17055
  • 3 weeks later...
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
