Pick the winner!
530 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok guys, here are all 30 entries for the competition, As its taken me an extra day to post this thread and the poll, the competition will run 1 day longer, so the most votes at 5pm (EST) 1/05/06 will win.
As sky106 had errors when uploading the submission and posted about this only 30mins after the close of entries, i have allowed his entry. Also, some people entered more than 1 banner, so I just picked one of the 2, you can't change the banner I picked for you as the rules stated only 1 entry per person.
Ok, simply vote in the poll for your favorite.
1. cjlancer
2. sav man
3. QRI05E
4. FILO34
5. ssslpr
6. justinfox
7. rein
8. wink
9. nizmokid
10. NYL83R
11. HRthirtyone
12. infokill
13. Shrub32
14. Sauce
15. Pac
16. rascov
17. Alien
18. Insomniac
19. oblivo
20. CPT STABBING
21. n13gl
22. Slide
23. Topaz
24. insu
25. Xinhua
26. Mr.iNFMS
27. Boostkid
28. sky106
Click here
  • Replies 59
<snip>
i like that flash banner, 28.
likin anything wit a aussie flag or southerncroos,
28
Edited by PranK
@ 4door:
Mate could you please edit your post and NOT quote Prank's post? We don't really need to have them all twice and you can show what you like by voting, if you haven't already :D
And what a high standard of entries! I'm blown away.
well # 9 is the goods not too much and has the Mines R34 GTR in the design!
has the dark colours but not too much to make it to drab!
you can't go wrong! hahahahaaha
but all the designs are cool guys!
I love your modesty.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
