:D for the street/old pac drivers. and for the track.
due to a couple of friends of mine loosing there engines from a simple lack of oil i thought id post up a easy guide on how to keep your engine from poping...
GTR OWNERS: when you change your oil, fill the carnt thing up to the hump on the dipstick.
this works out to be roughly 6 to 6.5 litres of oil.
if the oil level is on high. it will surge just acelerating in first gear. (not to mention corners)
i have done thorough testing of this and can asure you all that this quantity of oil is the MINIMUM that is required to combat oil surge in a standard sumped gtr.also a tomie baffeld one to.(makes no differance if its
baffeled or not.) (mechanical oil presure guages dont lie)
now. im not a fan of motul oils. but hey you guys love the shiet so yeah.
using a good quality synthetic oil with a cold rating of less than 15. and a hot rating of 50 or more is the go.
eg 5w60 penrite is my personal favorite. its the only one i have used that can stand up to a whole track day without "breaking down"
GTS-T OWNERS your cars have a much better sump design so you can get away with using abit less oil. 5.5-6 litres of oil is suficant. the rwd sumps still have poor bafeling anyway. so fill them to just before the hump on the dipstick.
so summing it up PUT OIL IN YOUR ENGINE its not hard to fill er up abit over full. it does no damage to the engine. it just keeps all those legs in bed.
so following this instruction it will extend the life or your RB by a long mark
the same rules aply to any RB powerd car with the standard CAPACITY sump
ps.. moderator please leave in nsw section as it is aimed at our own circle. cheeres :D
https://www.sau.com.au/forums/topic/115490-keeping-that-engine-alive/
  • Replies 55
But you don't recomment this for the street do you?
I changed my oil recently and as I had a track day coming in a few weeks I overfilled. Car goes fine, a bit more oil in the catch can (or spewing out of it in my case since it is a crap can) but the one thing I noticed is that when I start it up in the morning (or stone cold anyway) it burns oil for about 3-5 minutes. I can see it coming out the exhaust and my garage fills with fumes.
It didn't do this before. Can you explain it and is it ok?
yes. the same aplies
Mine has a oil controll problem at the moment... we built this RB30DET over 2.5 years ago and we did not know to block one of the oil feeds and put a restrictor so if i had more oil in the engine i would have an oil fountain lol
getting this done in the next month or so
i think you may have wire crossed steve-o. surge tank is used to combat fuel surge. there is no realy way to add an external surge tank for oil without going dry sump, in which case it's still not realyl a surge tank, just an oil, holding tank.
generally sump baffles are the way to go to help combat oil surge as they attempt to prevent oil from flowing away from the pick-up, or even better a larger sump and baffles, or at the extreme, dry sump. the only reason not everyone has them is fitting the sump baffles requires engine removal.
Yeah i thought that just after i posted it up - couldnt be bothered deleting it
Thanks richo - so far no fuel issues (touch wood) other than that damn fuel cap - it started leaking again today !!! but its only on very hard cornering
you wont get any more oil up there than normal. instead you will be pumping oil thru the motor not air!!
this is what people dont understand...
but if you wanna pull the head off to try and kinda make a diferance go rite ahead :(
Turbine and I just pulled my GTS4 RB20DET out this weekend and found that 4& 6 BigEnds were totaly cooked and stuffed from lack of oil.
Have had clattering noise for some time now and oil gauge always mostly reads very low but sometimes full scale so just dismissed the oil gauge sender as faulty which is common fault have been told.
Mostly filled to under high level so prob not enough for AWD GTS4 which has same sump as GTR & Stagea.
Over filling probably may not have saved my RB20 but it may have made it last longer so I will be filling my next motor up higher.
I am looking for a Stagea RB25DET if anyone knows of a near complete motor less Gbox.
Well if GTR's suffered from oil surge... this thread would actually be right
But they dont, the sump design is actually quite good.
The killing of bearings etc is due to other reasons, certainly not oil surge
A topic comes to mid actually... i love the search button :O
http://www.skylinesaustralia.com/forums/in...opic=110680&hl=
What oil is best for a 33gtst with only a turbo-back, front mount, pod and boost controller?
Try doing a search - there's a million threads on this (particularly in General Maintenance and Forced Induction)
For the record, I use Elf Excellium 5W-40 Full Synthetic
In saying that, I think a fair few people on here use Motul 300V Chrono, 8100 Excess or 4100 Turbolight - there's many to choose from that will do the job. Do the search and figure out what suits you best.
I guess it comes down to how much you want to pay, how modded your car is and how you use your car (i.e sunday driver, daily commuter or weekend warrior for example).
Update on an oil problem no-one could have fixed!
Found the reason for my oil problems - the back plate on the oil pump had come virtually off and most of the screws had come out!!
As this is inside the AWD sump and needed the complete block top be removed to identify the problem.
HOT DAMN!!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
