How about I let you have a run or 2 on the pan if we get a long enough break. You've been doing the marshalling while without a car so it's fair enough.
BTW I'm bringing a mate. I wanted to enter him and his MX-5 but he's a big girl.
My dilemma is, do I play it serious and bring the semi's or just have fun sliding big Purple??? And if it rains I'll need the wets for at least a little traction.
  • Replies 118
LOL...you pay the money, you should get as many runs as you can...dont volunteer seat time for me :woot:
Its still good fun even without a car...miniwog and co know how to ammuse the crowd, and Poite has taken over from me with limiter action so we have all bases covered forma spectating stance.
..and i have given up on gettign any accomodation. I am yet to actually sleep in the bed that i pay good money for...so this time im just goign to invest that accom money in more booz:)
I have released the event schedule for download. Please print and bring with you if you would like a colour copy.
Edited 1st Post.
Event Schedule: Click Here
If link doesn't work try here: Click Here
Entry list with competition numbers
1 Andrew Richmond* R34 GTR
2 Paul Rivoli*** R33 GTST
3 Will Stark**** WRX
4 Garry Matthews***** WRX
5 Damion Wilson WRX
6 Matt Lowth WRX
7 Dave Marinucci XR6T
8 Dane Stokes S13
9 Justine Schuller 200SX
10 Blaise Paris* R34 GTR
11 Karl** XR6T
12 Sarah Biggin*** R33 GTST
13 Helen White**** WRX
14 Alycia Matthews***** WRX
15 Ben Winstone R32 GTR
16 Nigel Beale Supra
17 Ang R32 GTR
18 Paul Di Lizia WRX STI
19 Jordan Walsh WRX
20 Chris Thomson R33 GTR
21 Scott Bailey TX5
22 Nick Edlin R33 GTST
23 Alan King Skoob
24 Al Calleja R33 GTST
25 Jarrod Moore R32 GTST
26 Ryan Bell Sil180
27 Dino Russel Mitsubishi RVR
28 Mario West 200SX
29 Martin Sullivan Bluebird
30 Justin Marcus R33 GTST
31 Nick Savvides BMW Z4
32 Scott Andrew R33 GTST
33 John Andrew R33 GTR
34 Michael Pope R32 GTR
35 Justin Masters R33 GTST
36 Tom Giordano R32 GTST
37 Tharaka Pathirage Mitzubishi Galant
38 Geoff Williams R33 GTR
39 William Lee R33 GTST
40 Russell Cunningham R32 GTST
41 Shan Moorthy R32 GTST
42 Peter Blythe R34 GTT
43 Craig Moore R33 GTST
44 Ben Lippa 180SX
45 Danny Spencer R33 GTST
46 Sharni Brown 180SX
47 Wayne Sterling R33 GTST
48 Jarrod Davis 180SX
Not bringing the cheaters unless it is raining.
I want to Sliiiii......iiiiiiiii.....iiiide.
Brisby, you'll take a run and damn well enjoy it. Don't make me kick your sooky Waratahs lovin' ass.
I trust there will be a little time for volunteers to take a run.
We'll have to see how the day pans out. A lot depends on the weather. If its fine and sunny we'll get through everyhting ok but if the skidpan is wet then we'll struggle to get through all the runs as it is.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
