As some of you are aware im selling copies of the Banana bar but i have run into a slight problem... I have No idea what indicators are being used in the bar and obviously makes it hard to sell the bar and have no idea what indicators it comes with...
If anyone can shed some light as to what indicators they are it would be very much appreciated.. I have spoken to Nissan and a few other places and no-one can tell me what they are…
Back dimensions are around 90x40mm at the base and span out to a 125x40mm at the front..
Attached is a shot of the indicator…
Thanx again in advance to anyone that can tell me what they are off cheers…
Matt
Also if your interested in the bar Link is below in the Sig....
https://www.sau.com.au/forums/topic/116924-i-need-some-help/
Dark cheers mate but there is nothing... All the indicators has is a Manufactures Number and Both Nissan and a second hand joint have both told me that the numbers mean Jack and im unable to order parts from the given markings..
Hence this being such a hard task
have u tried running the numbers through mitsibushi or toyota, cuz by the looks of those n the dimensions, it looks as its off a pre 98 Mitsibushi Canter (its a 1 ton truck, sorta).....i may be wrong but run the part number through mitsubishi.....wudn hurt.....
ok they are not 180sx ones are they??
Right Hand: B6170-60F00
Left Hand: B6175-60F00
I have been looking at some 180sx kits and the hole looks very very similar in the sqaure shape...but i have no dimentions...
Edited by khunjeng
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
