We are making a short run of Long Sleeve Commemorative Shirts for the 2006 DECA Motokhana Series.
The shirts are a black long sleeve cotton and will cost $40. Numbers are limited so this is an opportunity to reserve one for yourself now. If you are interested please post your name and the size you want and it will be reserved for you.
Attached is the shirt design.
Cheers
Snowy
Edit - All the 2006 DECA Shirts are long sleeved and they will all be black. Sizes are S, M, L, XL and XXL.
https://www.sau.com.au/forums/topic/116960-deca-series-commemorative-shirts/
  • Replies 70
Posted Images
OK
Just to confirm - all the 2006 DECA Shirts are long sleeved and they will all be black.
The template above is just to show the design and James didn't have a long sleeve template at the time of desiging.
If you know what size you want, you can resverve your shirt. If you are not sure what size you want, just come and try them on at DECA.
Cheers
B
I want a medium to large. Most likely medium.
Are they big sizings or small sizings? That can make my medium request become a large, or my large become a medium....
thats the boat im in...i thought we NEEDED to reserve them...but if they're will be enough at DECA anyway, ill try 1 on and grab the best size :P
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
