I have a pair of those scissors.....they are not that bloody sharp.
Ykhikyg lol
Pretty quiet over here in the qld section, headed out to willowbank on Wednesday not a great skyline turnout was a white 33 and a grey 33 both running in the 13s :/
10 years of SAU whoring today! Sad, I'm still here and have no Skyline.
I past 10 back in June under my original account...
And to think i just signed up to get some opinions around pricing on an R33 GTR back when they were 60-70k in fair condition... :D
You knew right then it was love at first type
Well id must say SAU saved me thousands on buying one...
As at the time the market was very small and not many R33 GTR's were around...
60k was a pretty average price, little did i know i could import on myself...
Saved me $20k on my first purchase, hung around since...
I am on here now and then, I dont own a skyline either, but I do own somthing that has all the heart of a skyline...
What ever happened to your 4 door Chris?
BTW, nice advendtures in europe... I followed your activity with jealousy...
I own two Subaru outbacks.
Lately I have taken to checking my pants just to see if I still have testicles.
My motorbike has more HP than my car...
oh oh and to top that, its automatic... :rofl:
same as me. 10.5 yrs - came here with a subaru and a startlet - now have two nissans..
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
