a motor on a tubed chassi cant really be compared to a full road car, stick that motor in somthing of a similar weight and just laugh at how much it sucks.
still pretty cool tho, racing from a roll, lol
i'd hardly call this "mind blowing"... just look at the power to weight ratio. I'd rather a full bodied car with all the luxury trims and still be damn quick.. than that kit car with "free" air conditioning :)
another aussie tryin to make a buck in america... tsk tsk
another KIWI inventing something amazing in the motor world... much like the guy who invented the jet boat and Mr. Britten who made a motorbike in his shed which was years ahead of its time.
the power to weight ratio isnt that much better then a Ferrari or the Porka and as stated its based on the Atom which is a road legal car.
the batteries in this version weigh over 250kgs alone from memory... id definately have one as a nice weekend track toy.
Power to weight advantage where????
Porka GT = 605BHP and 3000lbs
Aerial X1 = 300Bhp and 1500lbs
wheres the advantage? its at a disadvantage by my calculations as it has less then half the power but half the weight
dont like the way they compare it to full size cars, y not compare it to a Hayabusa or R1?
probably cause its not a motorbike?
so if they invented a mini that ran 10s from factory they shouldnt compare it to s super saloon?
its merely to show what you can achieve using alternate fuels. A point that seems to escape most people. The car is ELECTRIC. Performance electric cars are few and far between unless you count that ugly 600kw 6 wheeled japanese thing.
Exactly what inark said, the point of the clip was to examine the potential of alternative powers sources other than fossil fuels. One day there wont be any petrol to burn and we'll all prob be driving these 11 sec things. Another thing to consider is the price of petrol versus plugging your car in the wall for a few hours. As time goes on and technology progresses the weight on the batteries will come down aswell as provide more power.
Also there is no advantage, the power to weight is about the same anyway, WTF are you guys on??
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
