hey guys, i had a little accident and went up a gutter backwards........
rain plus corner plus me = :) missed the pole by less than a meter i reckon pooor car :)
soooo ill show pics lol since its the r32 pic thread i suppose,
ooops
Edited by Caza
32line very very nice
Can you please tell me name of those rims :)
How low is the car from centre of wheel cap to guard?
cheers,
they are Lenso GT-05 rims...
How low is the car from centre of wheel cap to guard?? no idea...
why does that measurement matter?
the lowest point of the car is about 120mm
cheers,
Ive got some shocks/springs waiting to fit on which will drop my car to 340mm (from centre to guard) wanted to know if it will be same as your car, as i want a ride height like yours :D
ahh, its approx 320mm from centre cap to guard...thats the front wheel...my front sits slightly lower than the rear
watch the height of ur exhaust if ur lowering ur car...ur exhaust will prolly hang lower than mine...cause i got mine lifted to pass rd worthy...now its clears the ground by 115-120mm
EDIT: also...the rims are 8's all round..with 225 at front 235 at rear. the fronts rub sumtimes in hard cornering...
AND...these lenso rims didnt clear the 4piston calipers at the front, they needed some minor modifying to spin freely without hittin the calipers :D
Edited by 32line
Hi Guys
Been reading and checking out the cars in this thread since it started and im amazed at the quality of cars and pic's that adorn the pages of this forum so thought it was about time I added mine .
first lot of pics is my old black 32 b4 its untimely end
post-7066-1184916328_thumb.jpg post-7066-1184916375_thumb.jpg post-7066-1184916419_thumb.jpg
And the new r32 bought june 06 fully rebuilt and near compleation may 07 post-7066-1184917145_thumb.jpg
post-7066-1184917284_thumb.jpg post-7066-1184917368_thumb.jpg post-7066-1184917441_thumb.jpg post-7066-1184917559_thumb.jpg
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
