Does anyone have pics of a R32 GTR (Gunmetal grey) with R34 GTR rims?
I have found every other possible colour except gmg... its annoying.
I wanna see if the two colours will go together.
These pics are not very big, but they all I got in gun metal grey 32's with 34 gtr rims:
And if you want my opinion I reckon the rims work really well with that colour 32!
Edited by r32line
What you done to the car Abu? Engine mods etc. I'm looking at getting twin cannon set up.. I just love the look.
Show us your new GTR :)
Car still has most of the below parts, some have been taken off as its been sold off
Apexi Power FC
Apexi AVCR
HKS cam gears
HKS2535
HKS dump pipe
HKS front pipe
Custom cat back twin canons
Blitz intercooler
BOSCH 040
GTR injectors
Z32 AFM
Tein coilovers
KAZAMA caster rods
EXEDY button clutch
Emotion XD9
Was around 205wkw on a safe tune, went good
No pictures of the GTR yet, will get some next week but won't be in this section unfortunately.. lol
clean 32 4dr mate :)
you sure its a genuine front bar? coz you will need gtr guards for it to fit properly cause gtr front is wider then gtst
nah you dont need GTR gaurds to make the front bar sit nicely, simply redrilling/grinding 2 wholes in the GTR reo bar (12mm to be exact) will bring the front bar foward enough to fold the sides of the bumper up to the gaurd leaving no gap and over hang :P
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
