That's hot man but your front bar looks warped?
What sizes and offsets are those wheels?
Yeah it is a bit, looks worse because the photo is shot pretty low. Brought two of them for $250 and sold one for $400 so I'm not to fussed.
The wheels are:
Rear - 18x9.5 +18 215/40
Front - 18x9 +13 215/40
took a couple shots this arvo and tonight, heres a few i mucked around with. Hard trying to get them looking nice without going too far :S, not sure if i did or not.
I included a few of the crappy night shots so i can get some advice :ph34r:
post-22805-1226068188_thumb.jpg post-22805-1226068202_thumb.jpg post-22805-1226068215_thumb.jpg post-22805-1226068228_thumb.jpg post-22805-1226068239_thumb.jpg post-22805-1226068355_thumb.jpg
oo very nice!
How did you get your black paint so shiny in the first pic?
The wheels are:
I can't believe you managed to stretch 215's onto a 9.5" rim. No tyre shop I know would do that and I know people that work at one!!
I was running 215/40/R17 on the front of my XD9s which were 17 x 9.5 + 17 and 225/40/R18 on the rear 18 x 10 + 18 :banana:
Some serious stretch
Here's a couple shots of how the wheels sit and tyre stretch, still need to sort front and rear camber. Was running 225/40 before these but they were rubbing quite a bit, might just be the design of the tyre there might be a 225/40 out there that fits a little better.
what size and offset on those rims? look tuff!
Front - 18x9 +13
Rear - 18x9.5 +18
You should be able to get away with that on the back
I had 18 x 10 + 18 on the back of my R32 with 235/40 tyres. The inner lip on the guard was rolled and we slightly pumped/flared the whole guard, not to much but just enough to tuck the wheel under
Fron't I had 17 x 9.5 + 17 with a 235/40 tyre and same deal, guard liner removed with the inner lip rolled and guard slighly pumped/flared
Man, you guys all freak me out with the size wheels you are jamming in under the GTSts. I want to run a 9.5" , maybe 10" rear but only because i want to run a 265 rear tyre :down:
Anyway, the car has 9" +20 offset which should be doable and when the guards have been pumped for that sized rim i should be able to get a 9.5" + 36 on the rear aand run 255 tyres.
Is anyone running wide rims with decent sized rubber?
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
