Well its not totally finished as i still have to get tyres for the TE37s and put on the titanium exhaust, drop the ride height a little and put some of the engine goodies on...but in the meantime.
I think the wing looks killer , its nice to see you try something different !
love the stance of your 32 mate
Thanks
love the grey and white combo... but damn you need some rear camber arms.. that is shocking.. there is no use for that much rear camber..
Thanks. yea thats the way i bought it, Its got adjustable camber arms on it , the wheels are some crazy offset and i have to roll the gaurds so i can straighten them out a bit. must admit though even with all that camber alot more tyre touches the ground than you think
Come a long way dude :)
Engine bay looks mint!!! What power is it making now?
Really makes me miss my ol' girl.
:ermm:
hey mate thanks ay it has come along way at the moment its untuned atm moment etc but once tuned headed for between 380-400awkws.So just savin for that tune now lol
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
