hey every1 i have finnaly got my car tuned today!!!! when i took it in, the air/fuel was on 19!!! so i am lucky i didnt melt the thing!!! any way here are the mods:
240 000 km
Front mount
3' exhaust
malpassi (r31nizmoid: "bandaid")
standard internals
standard injectors
trust tdo5/06
turbosmart 45mm pro gate
screamer
bosch 040 pump
safc ( the first 1 with the nobs)
thats about it off the top of my head
on only 15psi it made:
198.7 RWKW
707.7 N.M
i will try and get a graph tomorrow that shows the air/fuel but when i looked at it it was perfectly straight on 12 wich is good.
i wanted to run 17 psi but the wastegate was screwed in as far as it goes... i dunno if its the turbo or weather i need a stronger spring or the car just cant produce enough exhaust gasses.. i will put a bleader on the air line to the wastegate to c what happens..
all up so far this car only owes me $10000 so i am very happy with the result..
please tell me your thoughts.
Edited by lwboosted
https://www.sau.com.au/forums/topic/120177-dyno-results-r32-3gtst/
yeah that's be the max that the wastegate will run. to boost it higher put in a boost controller. make sure you have the boost controller set at the lowest boost setting to start off with. sounds obvious, but it will be fresh in your mind now so less chance of you forgetting.
but thats respectable power for a rb20.
nah i dont i emailed the guy i bought it off so hopefully i will get the info soon. and i still want to boost it up to 17 psi. my tuner said he would re do it for free when i up the boost. he said i have a lil left in the injectors and 17 psi will be close to what they will handle
before i got it tuned it came on full boost at about 4200 now it cames on at about 3900 - 4000, a little laggy but oh so fun when it comes in.. haha.
i am still waiting to find out what the specs of the turbo is and i am taking it back next week to boost it up to 17psi.
There was some markings inside the exhaust housing but i cant really remember what they were. I was told that ADVAN sell the turbo new so i emailed them and i am waiting for a reply. and that JMS had one for sale a while ago and they advertised it with a rating of 470hp.
here are some pics before i put it on..
i will keep trying to get info.
do u's want me to get the numbers that are engraved on the front comp cover?
i wouldnt say that its the max that the wastegate will rung i'd say its the spring thats in there.. either change the spring or buy a decent boost controller
Trust website- has a pic but no specs
http://www.trust-power.com/02greddy/turbine.html
Another Trust link (part of the kit) says it comes in a variety of housing sizes
http://www.trust-power.com/02greddy/turbo_kit.html
The 45mm Pro-gate has a screw on it?
Can you get a pic of it, ive never seen a pro-gate with a adjustable screw on the top.
Mine certainly didnt and not once ive seen since
Its always been a case of open it up and change springs to what you want.
Depending on when you purchased the gate it should come with a set of spring rates, the new 48mm teflon ones (which replaced the 45mm if i recall) come with about 4 i think which is awesome.
And car will push the gas, if you hear the gate open, its making the exhaust no worries
there is a pic of the wastegate.. the screw is on top as u can see.. but i found out that apparently it is a balancing bolt or something and it already has the biggest spring in it. so i will just run a bleed valve.. the gate is not ajustable..
still waiting on the info for the turbo apparently it hase a 20g exhaust housing..?? means nothing to me.
never seen one like that before, is it genuine?
but all you do is remove the 6 screws holding the hat/lid of the gate down, and swap springs.
you can most certainly get more than a 17psi spring.
Just get a 7psi and a 14psi spring = 21psi :laugh:
They sell them scaled, so a 7psi goes inside the 17psi one.
I bet it has a 10psi and a 7psi one in there now
oh ok that makes sence..
yeah it is genuine, i got into contact with turbo smart coz i thought by looks of it the bolt was some sort of ajustment. but they told me it was for balencing..
that would be great but for some reason i think my standard injectors would be quiet maxed out.. haha
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
